[GRASS-QA] GRASS QA: martinl |main.c main.c | no clones | 0
monsters |0 warnings
soccerlab.info at gmail.com
Sat Sep 12 20:09:42 EDT 2009
Hello martinl,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
File :grass/trunk/display/d.rast/main.c
Function
main(Begins at: 35, Ends at:137)
| New Metrics |Old Metrics|
Complexity: | 9 | * | WARNING | 9 |
ParamNBR: | 2 | * | WARNING | 2 |
CalledNBR: | 36 | * | WARNING | 36 |
LOC: | 103 | | OK | 103 |
Conclusion: | this function is a WARNING |
at least 3 values are close to an outlier please consider revising code!
parse_catlist(Begins at: 139, Ends at:169)
Complexity: | 7 | * | WARNING | 7 |
CalledNBR: | 9 | * | WARNING | 9 |
LOC: | 31 | | OK | 31 |
parse_d_mask_rule(Begins at: 234, Ends at:263)
Complexity: | 6 | * | WARNING | 6 |
ParamNBR: | 3 | | OK | 3 |
CalledNBR: | 11 | | OK | 11 |
LOC: | 30 | | OK | 30 |
at least 1 values are close to an outlier please consider revising code!
parse_mask_rule(Begins at: 203, Ends at:232)
parse_vallist(Begins at: 171, Ends at:201)
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 9 | ** | BABY-MONSTER | 9 |
LOC: | 31 | ** | BABY-MONSTER | 31 |
Conclusion: | this function is a BABY-MONSTER |
metric are OUT OF RANGE!
Clone analysis:
This file does not contain cloned functions
File :grass/trunk/display/d.vect/main.c
Function
icon_files(Begins at: 32, Ends at:76)
Complexity: | 8 | * | WARNING | 8 |
ParamNBR: | 1 | | OK | 1 |
CalledNBR: | 14 | * | WARNING | 14 |
LOC: | 45 | * | WARNING | 45 |
main(Begins at: 78, Ends at:720)
Complexity: | 80 | *** | MONSTER | 80 |
CalledNBR: | 202 | *** | MONSTER | 202 |
LOC: | 643 | *** | MONSTER | 643 |
Conclusion: | this function is a MONSTER |
Clone analysis:
____________________________________________
Threshold grass key metrics values at Sat Sep 12 20:09:42 EDT 2009 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 6 | 13 | 21 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 10 | 23 | 37 |
LOC: | 42 | 91 | 141 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
