[GRASS-QA] GRASS QA: martinl |open.c open_ogr.c | no clones | 0
monsters |0 warnings
soccerlab.info at gmail.com
Mon Sep 14 08:25:57 EDT 2009
Hello martinl,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
File :grass/trunk/lib/vector/Vlib/open.c
Function
Vect__open_old(Begins at: 124, Ends at:396)
| New Metrics |Old Metrics|
Complexity: | 31 | | OK | 31 |
ParamNBR: | 5 | | OK | 5 |
CalledNBR: | 102 | | OK | 102 |
LOC: | 273 | | OK | 273 |
Conclusion: | this function is a OK |
metrics are OK
Vect_coor_info(Begins at: 608, Ends at:646)
Complexity: | 6 | *** | MONSTER | 6 |
ParamNBR: | 2 | * | WARNING | 2 |
CalledNBR: | 11 | *** | MONSTER | 11 |
LOC: | 39 | *** | MONSTER | 39 |
Conclusion: | this function is a MONSTER |
metric are OUT OF RANGE!
Vect_maptype_info(Begins at: 656, Ends at:673)
Complexity: | 5 | * | WARNING | 5 |
ParamNBR: | 1 | | OK | 1 |
CalledNBR: | 4 | * | WARNING | 4 |
LOC: | 18 | | OK | 18 |
Conclusion: | this function is a WARNING |
at least 2 values are close to an outlier please consider revising code!
Vect_open_new(Begins at: 514, Ends at:597)
Complexity: | 8 | | OK | 8 |
ParamNBR: | 3 | | OK | 3 |
CalledNBR: | 43 | | OK | 43 |
LOC: | 84 | | OK | 84 |
metrics are OK
Vect_open_old(Begins at: 410, Ends at:413)
Complexity: | 1 | * | WARNING | 1 |
ParamNBR: | 3 | * | WARNING | 3 |
CalledNBR: | 1 | *** | MONSTER | 1 |
LOC: | 4 | * | WARNING | 4 |
Vect_open_old_head(Begins at: 464, Ends at:468)
Complexity: | 1 | | OK | 1 |
CalledNBR: | 1 | | OK | 1 |
LOC: | 5 | | OK | 5 |
at least 1 values are close to an outlier please consider revising code!
Vect_open_spatial_index(Begins at: 767, Ends at:832)
Complexity: | 2 | | OK | 2 |
ParamNBR: | 1 | * | WARNING | 1 |
CalledNBR: | 8 | | OK | 8 |
LOC: | 66 | | OK | 66 |
Vect_open_topo(Begins at: 686, Ends at:757)
Complexity: | 7 | | OK | 7 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 16 | | OK | 16 |
LOC: | 72 | * | WARNING | 72 |
Vect_open_update(Begins at: 427, Ends at:449)
Complexity: | 2 | * | WARNING | 2 |
CalledNBR: | 2 | * | WARNING | 2 |
LOC: | 23 | * | WARNING | 23 |
at least 3 values are close to an outlier please consider revising code!
Vect_open_update_head(Begins at: 482, Ends at:502)
LOC: | 21 | | OK | 21 |
Vect_set_open_level(Begins at: 96, Ends at:107)
CalledNBR: | 2 | | OK | 2 |
LOC: | 12 | | OK | 12 |
fatal_error(Begins at: 59, Ends at:71)
Complexity: | 5 | | OK | 5 |
LOC: | 13 | | OK | 13 |
metrics are OK
format(Begins at: 38, Ends at:42)
ParamNBR: | 0 | | OK | 0 |
metrics are OK
open_old_dummy(Begins at: 32, Ends at:35)
CalledNBR: | 0 | | OK | 0 |
LOC: | 4 | | OK | 4 |
metrics are OK
Clone analysis:
This file does not contain cloned functions
File :grass/trunk/lib/vector/Vlib/open_ogr.c
Function
V1_open_old_ogr(Begins at: 45, Ends at:104)
Complexity: | 6 | * | WARNING | 6 |
CalledNBR: | 17 | * | WARNING | 17 |
LOC: | 60 | * | WARNING | 60 |
V2_open_old_ogr(Begins at: 114, Ends at:190)
Complexity: | 8 | * | WARNING | 8 |
CalledNBR: | 22 | * | WARNING | 22 |
LOC: | 77 | * | WARNING | 77 |
Clone analysis:
____________________________________________
Threshold grass key metrics values at Mon Sep 14 08:25:57 EDT 2009 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 6 | 13 | 21 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 10 | 23 | 37 |
LOC: | 42 | 91 | 141 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
