[GRASS-QA] GRASS QA: mmetz |do_astar.c do_cum.c Gwater.h
init_vars.c ...| 1 clones | 0 monsters |0 warnings
soccerlab.info at gmail.com
Tue Sep 29 03:36:15 EDT 2009
Hello mmetz,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
File :grass/trunk/raster/r.watershed/ram/do_astar.c
Function
add_pt(Begins at: 107, Ends at:133)
| New Metrics |Old Metrics|
Complexity: | 2 | | OK | 2 |
ParamNBR: | 6 | ** | BABY-MONSTER | 6 |
CalledNBR: | 4 | | OK | 4 |
LOC: | 27 | | OK | 27 |
Conclusion: | this function is a BABY-MONSTER |
metric are OUT OF RANGE!
add_pt(Begins at: 108, Ends at:134)
ParamNBR: | 4 | * | WARNING | 6 |
Conclusion: | this function is a WARNING |
at least 1 values are close to an outlier please consider revising code!
do_astar(Begins at: 6, Ends at:105)
Complexity: | 9 | * | WARNING | 9 |
ParamNBR: | 1 | | OK | 1 |
CalledNBR: | 15 | * | WARNING | 15 |
LOC: | 100 | ** | BABY-MONSTER | 100 |
drop_pt(Begins at: 137, Ends at:216)
Complexity: | 8 | * | WARNING | 8 |
CalledNBR: | 5 | | OK | 5 |
LOC: | 80 | * | WARNING | 80 |
at least 2 values are close to an outlier please consider revising code!
get_slope(Begins at: 264, Ends at:280)
Complexity: | 4 | | OK | 4 |
ParamNBR: | 6 | | OK | 6 |
CalledNBR: | 0 | | OK | 0 |
LOC: | 17 | * | WARNING | 17 |
replace(Begins at: 284, Ends at:305)
Complexity: | 3 | | OK | 3 |
ParamNBR: | 4 | * | WARNING | 4 |
LOC: | 22 | | OK | 22 |
Clone analysis:
This file does not contain cloned functions
File :grass/trunk/raster/r.watershed/ram/do_cum.c
Function
do_cum(Begins at: 6, Ends at:74)
Complexity: | 13 | *** | MONSTER | 13 |
CalledNBR: | 19 | *** | MONSTER | 19 |
LOC: | 69 | *** | MONSTER | 69 |
Conclusion: | this function is a MONSTER |
do_cum_mfd(Begins at: 98, Ends at:371)
Complexity: | 44 | | OK | 44 |
CalledNBR: | 55 | | OK | 55 |
LOC: | 274 | | OK | 274 |
Conclusion: | this function is a OK |
metrics are OK
mfd_pow(Begins at: 373, Ends at:386)
Complexity: | 3 | ** | BABY-MONSTER | 3 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 0 | * | WARNING | 0 |
LOC: | 14 | * | WARNING | 14 |
Clone analysis:
This file has 1 potentially cloned functions:
In /var/project-manager/grass/grassSVN/grass/trunk/raster/r.watershed/ram/do_cum.c clones of mfd_pow are:
/var/project-manager/grass/grassSVN/grass/trunk/raster/r.watershed/seg/do_cum.c mfd_pow
File :grass/trunk/raster/r.watershed/ram/Gwater.h
The system don't find class, method and function
in this file during analysis!
File :grass/trunk/raster/r.watershed/ram/init_vars.c
Function
ele_round(Begins at: 459, Ends at:471)
LOC: | 13 | | OK | 13 |
metrics are OK
init_vars(Begins at: 9, Ends at:457)
Complexity: | 107 | | OK | 107 |
CalledNBR: | 186 | | OK | 186 |
LOC: | 449 | | OK | 449 |
metrics are OK
Clone analysis:
File :grass/trunk/raster/r.watershed/ram/main.c
Function
main(Begins at: 65, Ends at:100)
Complexity: | 5 | | OK | 5 |
CalledNBR: | 22 | * | WARNING | 22 |
LOC: | 36 | | OK | 36 |
Clone analysis:
File :grass/trunk/raster/r.watershed/ram/ramseg.c
Function
size_array(Begins at: 4, Ends at:15)
Complexity: | 1 | | OK | 1 |
ParamNBR: | 3 | * | WARNING | 3 |
LOC: | 12 | | OK | 12 |
Clone analysis:
____________________________________________
Threshold grass key metrics values at Tue Sep 29 03:36:15 EDT 2009 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 6 | 13 | 21 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 10 | 23 | 37 |
LOC: | 42 | 91 | 141 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
