[GRASS-QA] GRASS QA: mmetz |write.c main.c rectify.c | no clones |
	0 monsters |2 warnings
    soccerlab.info at gmail.com
    Tue Aug 10 12:35:15 EDT 2010
Hello mmetz,
here's a report on your recent grass-SVN change for the revision : 42897
ANALYSIS
your changes to files/class/methods/functions :
          File :/imagery/i.rectify/write.c
          Function
write_map(Begins at: 39, Ends at:64)
              |          New Metrics           |Old Metrics|
Complexity:   |       3 |       |           OK |         3 |
ParamNBR:     |       1 |       |           OK |         1 |
CalledNBR:    |      14 |       |           OK |        14 |
LOC:          |      26 |       |           OK |        26 |
Conclusion:   | this function is a            OK           |
metrics are OK
Clone analysis:
This file does not contain cloned functions
          File :/imagery/i.rectify/main.c
          Function
main(Begins at: 67, Ends at:210)
Complexity:   |      17 |     * |      WARNING |        17 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |      52 |    ** | BABY-MONSTER |        52 |
LOC:          |     144 |     * |      WARNING |       144 |
Conclusion:   | this function is a  BABY-MONSTER           |
 metric are OUT OF RANGE!
Clone analysis:
          File :/imagery/i.rectify/rectify.c
          Function
rectify(Begins at: 14, Ends at:108)
Complexity:   |       8 |       |           OK |         8 |
ParamNBR:     |       4 |     * |      WARNING |         4 |
CalledNBR:    |      24 |     * |      WARNING |        24 |
LOC:          |      95 |     * |      WARNING |        95 |
Conclusion:   | this function is a       WARNING           |
 at least 3 values are close to an outlier please consider revising code!
Clone analysis:
____________________________________________
Threshold grass key metrics values at Tue Aug 10 12:35:14 EDT 2010 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         9 |        21 |        33 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        18 |        42 |        66 |
LOC:                  |        65 |       147 |       230 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
