[GRASS-QA] GRASS QA: mmetz |remove_areas.c write_nat.c build_nat.c
| no clones | 3 monsters |2 warnings
soccerlab.info at gmail.com
Tue Aug 10 15:18:41 EDT 2010
Hello mmetz,
here's a report on your recent grass-SVN change for the revision : 42962
ANALYSIS
your changes to files/class/methods/functions :
File :/lib/vector/Vlib/remove_areas.c
Function
Vect_remove_small_areas(Begins at: 35, Ends at:185)
| New Metrics |Old Metrics|
Complexity: | 21 | ** | BABY-MONSTER | 21 |
ParamNBR: | 4 | * | WARNING | 4 |
CalledNBR: | 45 | ** | BABY-MONSTER | 45 |
LOC: | 151 | ** | BABY-MONSTER | 151 |
Conclusion: | this function is a BABY-MONSTER |
metric are OUT OF RANGE!
Vect_remove_small_areas_faster(Begins at: 188, Ends at:316)
Complexity: | 17 | * | WARNING | 17 |
CalledNBR: | 38 | * | WARNING | 38 |
LOC: | 129 | * | WARNING | 129 |
Conclusion: | this function is a WARNING |
at least 4 values are close to an outlier please consider revising code!
Vect_remove_small_areas_fastest(Begins at: 319, Ends at:660)
Complexity: | 64 | *** | MONSTER | 64 |
CalledNBR: | 117 | *** | MONSTER | 117 |
LOC: | 342 | *** | MONSTER | 342 |
Conclusion: | this function is a MONSTER |
Clone analysis:
This file does not contain cloned functions
File :/lib/vector/Vlib/write_nat.c
Function
V2__add_line_to_topo_nat(Begins at: 136, Ends at:305)
Complexity: | 34 | *** | MONSTER | 34 |
CalledNBR: | 33 | * | WARNING | 33 |
LOC: | 170 | ** | BABY-MONSTER | 170 |
V2_delete_line_nat(Begins at: 655, Ends at:841)
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 42 | ** | BABY-MONSTER | 42 |
LOC: | 187 | ** | BABY-MONSTER | 187 |
Clone analysis:
File :/lib/vector/Vlib/build_nat.c
Function
Vect_attach_isles(Begins at: 306, Ends at:332)
Complexity: | 4 | | OK | 4 |
CalledNBR: | 5 | | OK | 5 |
LOC: | 27 | | OK | 27 |
Conclusion: | this function is a OK |
metrics are OK
Clone analysis:
____________________________________________
Threshold grass key metrics values at Tue Aug 10 15:18:36 EDT 2010 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 9 | 21 | 33 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 17 | 41 | 65 |
LOC: | 65 | 147 | 230 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
