[GRASS-QA] GRASS QA: mmetz |main.c geom.c global.h | no clones | 2
	monsters |1 warnings
    soccerlab.info at gmail.com
    Wed Aug 11 07:43:34 EDT 2010
Hello mmetz,
here's a report on your recent grass-SVN change for the revision : 43040
ANALYSIS
your changes to files/class/methods/functions :
          File :/vector/v.in.ogr/main.c
          Function
main(Begins at: 50, Ends at:1222)
              |          New Metrics           |Old Metrics|
Complexity:   |     117 |   *** |      MONSTER |       117 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |     458 |   *** |      MONSTER |       458 |
LOC:          |    1173 |   *** |      MONSTER |      1173 |
Conclusion:   | this function is a       MONSTER           |
 metric are OUT OF RANGE!
Clone analysis:
This file does not contain cloned functions
          File :/vector/v.in.ogr/geom.c
          Function
poly_count(Begins at: 162, Ends at:190)
Complexity:   |       5 |       |           OK |         5 |
ParamNBR:     |       1 |       |           OK |         1 |
CalledNBR:    |      10 |       |           OK |        10 |
LOC:          |      29 |       |           OK |        29 |
Conclusion:   | this function is a            OK           |
metrics are OK
geom(Begins at: 193, Ends at:413)
Complexity:   |      35 |   *** |      MONSTER |        35 |
ParamNBR:     |       7 |    ** | BABY-MONSTER |         7 |
CalledNBR:    |      85 |   *** |      MONSTER |        85 |
LOC:          |     221 |    ** | BABY-MONSTER |       221 |
centroid(Begins at: 31, Ends at:159)
Complexity:   |      18 |     * |      WARNING |        18 |
CalledNBR:    |      42 |    ** | BABY-MONSTER |        42 |
LOC:          |     129 |     * |      WARNING |       129 |
Conclusion:   | this function is a  BABY-MONSTER           |
Clone analysis:
          File :/vector/v.in.ogr/global.h
The system don't find class, method and function
 in this file during analysis!
____________________________________________
Threshold grass key metrics values at Wed Aug 11 07:43:31 EDT 2010 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         9 |        19 |        30 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        17 |        42 |        67 |
LOC:                  |        65 |       146 |       227 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
