[GRASS-QA] GRASS QA: mmetz |open.c | 1 clones | 0 monsters |1 warnings
soccerlab.info at gmail.com
Thu Aug 12 14:08:26 EDT 2010
Hello mmetz,
here's a report on your recent grass-SVN change for the revision : 43079
ANALYSIS
your changes to files/class/methods/functions :
File :/lib/vector/Vlib/open.c
Function
Vect_open_sidx(Begins at: 956, Ends at:1044)
| New Metrics |Old Metrics|
Complexity: | 11 | * | WARNING | 11 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 17 | * | WARNING | 17 |
LOC: | 89 | * | WARNING | 89 |
Conclusion: | this function is a WARNING |
at least 3 values are close to an outlier please consider revising code!
Clone analysis:
This file has 1 potentially cloned functions:
In /data/project-manager/grass/grassSVN/grass/trunk/lib/vector/Vlib/open.c clones of Vect_open_sidx are:
/var/project-manager/grass/grassSVN/grass/trunk/lib/vector/Vlib/open.c Vect_open_sidx
____________________________________________
Threshold grass key metrics values at Thu Aug 12 14:08:23 EDT 2010 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 9 | 19 | 30 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 17 | 41 | 65 |
LOC: | 65 | 147 | 230 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
