[GRASS-QA] GRASS QA: hamish |main.c r_frame.c r_vlegend.c eps.c
...| no clones | 3 monsters |61 warnings
soccerlab.info at gmail.com
Thu Dec 9 08:08:03 EST 2010
Hello hamish,
here's a report on your recent grass-SVN change for the revision : 44573
ANALYSIS
your changes to files/class/methods/functions :
File :/postscript/ps.output/main.c
Function
main(Begins at: 31, Ends at:288)
| New Metrics |Old Metrics|
Complexity: | 40 | *** | MONSTER | 40 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 95 | *** | MONSTER | 95 |
LOC: | 258 | *** | MONSTER | 258 |
Conclusion: | this function is a MONSTER |
metric are OUT OF RANGE!
Clone analysis:
This file does not contain cloned functions
File :/postscript/ps.output/r_frame.c
Function
read_frame(Begins at: 36, Ends at:112)
Complexity: | 21 | * | WARNING | 21 |
ParamNBR: | 1 | | OK | 1 |
CalledNBR: | 22 | * | WARNING | 22 |
LOC: | 77 | * | WARNING | 77 |
Conclusion: | this function is a WARNING |
at least 3 values are close to an outlier please consider revising code!
Clone analysis:
File :/postscript/ps.output/r_vlegend.c
Function
read_vlegend(Begins at: 19, Ends at:89)
Complexity: | 14 | * | WARNING | 14 |
CalledNBR: | 23 | * | WARNING | 23 |
LOC: | 71 | * | WARNING | 71 |
Clone analysis:
File :/postscript/ps.output/eps.c
Function
eps_draw(Begins at: 107, Ends at:130)
Complexity: | 3 | | OK | 3 |
ParamNBR: | 6 | ** | BABY-MONSTER | 6 |
CalledNBR: | 11 | | OK | 11 |
LOC: | 24 | | OK | 24 |
Conclusion: | this function is a BABY-MONSTER |
eps_bbox(Begins at: 18, Ends at:48)
Complexity: | 5 | | OK | 5 |
ParamNBR: | 5 | * | WARNING | 5 |
LOC: | 31 | | OK | 31 |
at least 1 values are close to an outlier please consider revising code!
eps_save(Begins at: 70, Ends at:85)
ParamNBR: | 3 | * | WARNING | 3 |
CalledNBR: | 6 | | OK | 6 |
LOC: | 16 | | OK | 16 |
pat_save(Begins at: 134, Ends at:153)
Complexity: | 4 | | OK | 4 |
CalledNBR: | 8 | | OK | 8 |
LOC: | 20 | | OK | 20 |
Clone analysis:
File :/postscript/ps.output/set_note.c
Function
note_in_file(Begins at: 136, Ends at:158)
CalledNBR: | 9 | | OK | 9 |
LOC: | 23 | | OK | 23 |
Conclusion: | this function is a OK |
metrics are OK
set_note(Begins at: 21, Ends at:134)
CalledNBR: | 37 | * | WARNING | 37 |
LOC: | 114 | * | WARNING | 114 |
Clone analysis:
File :/postscript/ps.output/r_scalebar.c
Function
read_scalebar(Begins at: 23, Ends at:164)
Complexity: | 32 | ** | BABY-MONSTER | 32 |
CalledNBR: | 50 | ** | BABY-MONSTER | 50 |
LOC: | 142 | * | WARNING | 142 |
Clone analysis:
File :/postscript/ps.output/val_list.c
Function
sort_list(Begins at: 14, Ends at:46)
Complexity: | 7 | | OK | 7 |
CalledNBR: | 4 | | OK | 4 |
LOC: | 33 | | OK | 33 |
parse_val_list(Begins at: 71, Ends at:109)
LOC: | 39 | | OK | 39 |
metrics are OK
Clone analysis:
File :/postscript/ps.output/proj_geo.c
Function
find_limits(Begins at: 48, Ends at:85)
CalledNBR: | 13 | | OK | 13 |
LOC: | 38 | | OK | 38 |
Clone analysis:
File :/postscript/ps.output/set_vector.c
Function
set_vector(Begins at: 23, Ends at:85)
CalledNBR: | 12 | | OK | 12 |
LOC: | 63 | | OK | 63 |
Clone analysis:
File :/postscript/ps.output/set_scalebar.c
Function
set_scalebar(Begins at: 12, Ends at:202)
Complexity: | 28 | ** | BABY-MONSTER | 28 |
CalledNBR: | 61 | ** | BABY-MONSTER | 61 |
LOC: | 191 | ** | BABY-MONSTER | 191 |
Clone analysis:
File :/postscript/ps.output/r_draw.c
Function
read_draw(Begins at: 22, Ends at:54)
metrics are OK
Clone analysis:
File :/postscript/ps.output/set_vlabels.c
Function
set_vlabels(Begins at: 22, Ends at:92)
Complexity: | 10 | * | WARNING | 10 |
CalledNBR: | 18 | | OK | 18 |
at least 2 values are close to an outlier please consider revising code!
Clone analysis:
File :/postscript/ps.output/set_vareas.c
Function
set_vareas_line(Begins at: 168, Ends at:240)
CalledNBR: | 19 | * | WARNING | 19 |
LOC: | 73 | * | WARNING | 73 |
set_vareas(Begins at: 46, Ends at:165)
Complexity: | 20 | * | WARNING | 20 |
CalledNBR: | 38 | * | WARNING | 38 |
LOC: | 120 | * | WARNING | 120 |
Clone analysis:
File :/postscript/ps.output/set_vlines.c
Function
set_vlines(Begins at: 39, Ends at:145)
CalledNBR: | 31 | * | WARNING | 31 |
LOC: | 107 | * | WARNING | 107 |
at least 4 values are close to an outlier please consider revising code!
Clone analysis:
File :/postscript/ps.output/r_vlabels.c
Function
read_vlabels(Begins at: 21, Ends at:148)
LOC: | 128 | * | WARNING | 128 |
Clone analysis:
File :/postscript/ps.output/set_geogrid.c
Function
set_numbers_geogrid(Begins at: 90, Ends at:163)
Complexity: | 9 | | OK | 9 |
LOC: | 74 | * | WARNING | 74 |
set_geogrid_lines(Begins at: 34, Ends at:86)
Complexity: | 6 | | OK | 6 |
CalledNBR: | 17 | | OK | 17 |
LOC: | 53 | | OK | 53 |
metrics are OK
Clone analysis:
File :/postscript/ps.output/r_font.c
Function
read_font(Begins at: 55, Ends at:100)
LOC: | 46 | | OK | 46 |
Clone analysis:
File :/postscript/ps.output/set_vpoints.c
Function
set_vpoints_line(Begins at: 123, Ends at:227)
CalledNBR: | 25 | * | WARNING | 25 |
LOC: | 105 | * | WARNING | 105 |
set_vpoints(Begins at: 22, Ends at:120)
Complexity: | 16 | * | WARNING | 16 |
LOC: | 99 | * | WARNING | 99 |
Clone analysis:
File :/postscript/ps.output/r_vlines.c
Function
read_vlines(Begins at: 21, Ends at:180)
Complexity: | 29 | ** | BABY-MONSTER | 29 |
CalledNBR: | 57 | ** | BABY-MONSTER | 57 |
LOC: | 160 | ** | BABY-MONSTER | 160 |
Clone analysis:
File :/postscript/ps.output/set_rlegend.c
Function
set_rlegend_cats(Begins at: 20, Ends at:179)
Complexity: | 19 | * | WARNING | 19 |
CalledNBR: | 55 | ** | BABY-MONSTER | 55 |
set_rlegend_gradient(Begins at: 182, Ends at:334)
Complexity: | 15 | * | WARNING | 15 |
LOC: | 153 | ** | BABY-MONSTER | 153 |
Clone analysis:
File :/postscript/ps.output/ps3_map.c
The system don't find class, method and function
in this file during analysis!
File :/postscript/ps.output/set_mask.c
Function
set_mask(Begins at: 19, Ends at:101)
CalledNBR: | 35 | * | WARNING | 35 |
LOC: | 83 | * | WARNING | 83 |
Clone analysis:
File :/postscript/ps.output/r_note.c
Function
read_note(Begins at: 22, Ends at:86)
Complexity: | 12 | * | WARNING | 12 |
LOC: | 65 | | OK | 65 |
Clone analysis:
File :/postscript/ps.output/format.c
File :/postscript/ps.output/start_map.c
Function
start_map(Begins at: 21, Ends at:99)
LOC: | 79 | * | WARNING | 79 |
Clone analysis:
File :/postscript/ps.output/set_draw.c
Function
label_in_file(Begins at: 300, Ends at:408)
CalledNBR: | 54 | ** | BABY-MONSTER | 54 |
LOC: | 109 | * | WARNING | 109 |
set_draw(Begins at: 27, Ends at:297)
Complexity: | 62 | *** | MONSTER | 62 |
CalledNBR: | 136 | *** | MONSTER | 136 |
LOC: | 271 | *** | MONSTER | 271 |
set_on_paper(Begins at: 411, Ends at:444)
ParamNBR: | 4 | * | WARNING | 4 |
LOC: | 34 | | OK | 34 |
Clone analysis:
File :/postscript/ps.output/set_outline.c
Function
set_outline(Begins at: 18, Ends at:73)
CalledNBR: | 30 | * | WARNING | 30 |
LOC: | 56 | | OK | 56 |
Clone analysis:
File :/postscript/ps.output/r_maparea.c
Function
read_maparea(Begins at: 21, Ends at:90)
Complexity: | 17 | * | WARNING | 17 |
LOC: | 70 | * | WARNING | 70 |
Clone analysis:
File :/postscript/ps.output/r_block.c
Function
read_block(Begins at: 20, Ends at:64)
Complexity: | 11 | * | WARNING | 11 |
CalledNBR: | 10 | | OK | 10 |
LOC: | 45 | | OK | 45 |
Clone analysis:
File :/postscript/ps.output/palettes.c
Function
HSV_RGB(Begins at: 340, Ends at:393)
CalledNBR: | 1 | | OK | 1 |
LOC: | 54 | | OK | 54 |
monochrome(Begins at: 102, Ends at:128)
LOC: | 27 | | OK | 27 |
palette_new(Begins at: 23, Ends at:31)
Complexity: | 1 | | OK | 1 |
CalledNBR: | 2 | | OK | 2 |
LOC: | 9 | | OK | 9 |
metrics are OK
analogous(Begins at: 164, Ends at:193)
CalledNBR: | 3 | | OK | 3 |
LOC: | 30 | | OK | 30 |
gray(Begins at: 81, Ends at:99)
Complexity: | 2 | | OK | 2 |
LOC: | 19 | | OK | 19 |
metrics are OK
pure_color(Begins at: 59, Ends at:78)
metrics are OK
diverging(Begins at: 234, Ends at:271)
gradient(Begins at: 196, Ends at:231)
LOC: | 36 | | OK | 36 |
complementary(Begins at: 131, Ends at:161)
RGB_HSV(Begins at: 281, Ends at:334)
CalledNBR: | 0 | | OK | 0 |
Clone analysis:
File :/postscript/ps.output/set_raster.c
Function
set_raster_maskcell(Begins at: 201, Ends at:282)
CalledNBR: | 26 | * | WARNING | 26 |
LOC: | 82 | * | WARNING | 82 |
set_raster_maskcolor(Begins at: 286, Ends at:348)
set_raster_rgb(Begins at: 143, Ends at:197)
Complexity: | 8 | | OK | 8 |
CalledNBR: | 21 | * | WARNING | 21 |
LOC: | 55 | | OK | 55 |
set_raster_cell(Begins at: 102, Ends at:140)
metrics are OK
Clone analysis:
File :/postscript/ps.output/set_ps.c
Function
set_xy_where(Begins at: 59, Ends at:71)
LOC: | 13 | | OK | 13 |
set_ps_symbol_eps(Begins at: 149, Ends at:170)
LOC: | 22 | | OK | 22 |
metrics are OK
set_ps_pattern(Begins at: 93, Ends at:144)
LOC: | 52 | | OK | 52 |
set_ps_where(Begins at: 42, Ends at:54)
is_xy_outside(Begins at: 73, Ends at:88)
metrics are OK
Clone analysis:
File :/postscript/ps.output/r_grid.c
Function
read_grid(Begins at: 21, Ends at:149)
Complexity: | 24 | ** | BABY-MONSTER | 24 |
CalledNBR: | 40 | * | WARNING | 40 |
LOC: | 129 | * | WARNING | 129 |
Clone analysis:
File :/postscript/ps.output/local_proto.h
File :/postscript/ps.output/load_raster.c
Function
load_group(Begins at: 37, Ends at:87)
CalledNBR: | 20 | * | WARNING | 20 |
LOC: | 51 | | OK | 51 |
load_cell(Begins at: 90, Ends at:140)
CalledNBR: | 15 | | OK | 15 |
metrics are OK
Clone analysis:
File :/postscript/ps.output/r_vareas.c
Function
read_vareas(Begins at: 21, Ends at:203)
CalledNBR: | 65 | ** | BABY-MONSTER | 65 |
LOC: | 183 | ** | BABY-MONSTER | 183 |
Clone analysis:
File :/postscript/ps.output/scanners.c
File :/postscript/ps.output/r_paper.c
Function
read_paper(Begins at: 18, Ends at:115)
Complexity: | 22 | ** | BABY-MONSTER | 22 |
LOC: | 98 | * | WARNING | 98 |
Clone analysis:
File :/postscript/ps.output/set_vlegend.c
Function
make_vlines(Begins at: 258, Ends at:308)
CalledNBR: | 16 | | OK | 16 |
metrics are OK
make_vpoints(Begins at: 310, Ends at:369)
LOC: | 60 | | OK | 60 |
make_vareas(Begins at: 195, Ends at:256)
LOC: | 62 | | OK | 62 |
Clone analysis:
File :/postscript/ps.output/r_vpoints.c
Function
read_vpoints(Begins at: 21, Ends at:245)
Complexity: | 49 | *** | MONSTER | 49 |
CalledNBR: | 78 | *** | MONSTER | 78 |
LOC: | 225 | ** | BABY-MONSTER | 225 |
Clone analysis:
File :/postscript/ps.output/r_rlegend.c
Function
read_rlegend(Begins at: 20, Ends at:161)
Complexity: | 27 | ** | BABY-MONSTER | 27 |
Clone analysis:
File :/postscript/ps.output/r_raster.c
Function
read_raster(Begins at: 20, Ends at:139)
Complexity: | 23 | ** | BABY-MONSTER | 23 |
Clone analysis:
File :/postscript/ps.output/symbol.c
Function
draw_chain(Begins at: 14, Ends at:47)
metrics are OK
symbol_save(Begins at: 50, Ends at:126)
Clone analysis:
File :/postscript/ps.output/palettes.h
File :/postscript/ps.output/ps_info.h
Class
PS3_info(Begins at: 31, Ends at:79)
| DIT | NOC | WMC | RFC | CBO | LCOM |
|NEW Metrics | 1 | 0 | 0 | 0 | 0 | 0 |
|OLD Metrics | 1 | 0 | 0 | 0 | 0 | 0 |
Clone analysis:
File :/postscript/ps.output/input.c
Function
input(Begins at: 19, Ends at:48)
metrics are OK
Clone analysis:
File :/postscript/ps.output/set_grid.c
Function
set_grid_lines(Begins at: 33, Ends at:125)
LOC: | 93 | * | WARNING | 93 |
set_numbers_grid(Begins at: 131, Ends at:192)
CalledNBR: | 24 | * | WARNING | 24 |
Clone analysis:
File :/postscript/ps.output/cat_val.c
Function
get_number(Begins at: 54, Ends at:83)
get_string(Begins at: 86, Ends at:123)
load_catval_array(Begins at: 19, Ends at:48)
Clone analysis:
File :/postscript/ps.output/r_line.c
Function
read_psline(Begins at: 31, Ends at:136)
LOC: | 106 | * | WARNING | 106 |
Clone analysis:
File :/postscript/ps.output/r_palette.c
Function
read_palette(Begins at: 26, Ends at:133)
CalledNBR: | 33 | * | WARNING | 33 |
LOC: | 108 | * | WARNING | 108 |
Clone analysis:
____________________________________________
Threshold grass key metrics values at Thu Dec 09 08:07:55 EST 2010 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 10 | 22 | 34 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 19 | 46 | 73 |
LOC: | 68 | 153 | 239 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
