[GRASS-QA] GRASS QA: mmetz |main.c do_cum.c sg_factor.c do_astar.c
...| 4 clones | 3 monsters |21 warnings
soccerlab.info at gmail.com
Fri Dec 17 06:22:59 EST 2010
Hello mmetz,
here's a report on your recent grass-SVN change for the revision : 44625
ANALYSIS
your changes to files/class/methods/functions :
File :/raster/r.watershed/seg/main.c
Function
main(Begins at: 69, Ends at:110)
| New Metrics |Old Metrics|
Complexity: | 6 | | OK | 6 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 18 | * | WARNING | 18 |
LOC: | 42 | | OK | 42 |
Conclusion: | this function is a WARNING |
at least 1 values are close to an outlier please consider revising code!
Clone analysis:
This file has 1 potentially cloned functions:
In /data/project-manager/grass/grassSVN/grass/trunk/raster/r.watershed/seg/main.c clones of main are:
/var/project-manager/grass/grassSVN/grass/trunk/raster/r.watershed/seg/main.c main
File :/raster/r.watershed/seg/do_cum.c
Function
do_cum(Begins at: 8, Ends at:94)
Complexity: | 13 | * | WARNING | 13 |
ParamNBR: | 1 | | OK | 1 |
CalledNBR: | 26 | * | WARNING | 26 |
LOC: | 87 | * | WARNING | 87 |
at least 3 values are close to an outlier please consider revising code!
do_cum_mfd(Begins at: 118, Ends at:437)
Complexity: | 44 | *** | MONSTER | 44 |
CalledNBR: | 63 | ** | BABY-MONSTER | 63 |
LOC: | 320 | *** | MONSTER | 320 |
Conclusion: | this function is a MONSTER |
metric are OUT OF RANGE!
Clone analysis:
This file does not contain cloned functions
File :/raster/r.watershed/seg/sg_factor.c
Function
sg_factor(Begins at: 6, Ends at:48)
Complexity: | 8 | | OK | 8 |
CalledNBR: | 12 | | OK | 12 |
LOC: | 43 | | OK | 43 |
Conclusion: | this function is a OK |
metrics are OK
Clone analysis:
File :/raster/r.watershed/seg/do_astar.c
Function
cmp_pnt(Begins at: 176, Ends at:185)
Complexity: | 4 | | OK | 4 |
CalledNBR: | 0 | | OK | 0 |
LOC: | 10 | | OK | 10 |
metrics are OK
do_astar(Begins at: 11, Ends at:172)
Complexity: | 22 | ** | BABY-MONSTER | 22 |
CalledNBR: | 39 | * | WARNING | 39 |
LOC: | 162 | ** | BABY-MONSTER | 162 |
Conclusion: | this function is a BABY-MONSTER |
add_pt(Begins at: 188, Ends at:207)
Complexity: | 1 | | OK | 1 |
ParamNBR: | 3 | * | WARNING | 3 |
CalledNBR: | 1 | | OK | 1 |
LOC: | 20 | | OK | 20 |
Clone analysis:
This file has 2 potentially cloned functions:
cmp_pnt
In /data/project-manager/grass/grassSVN/grass/trunk/raster/r.watershed/seg/do_astar.c clones of cmp_pnt are:
/data/project-manager/grass/grassSVN/grass-addons/grass7/raster/r.stream.extract/do_astar.c heap_cmp
/var/project-manager/grass/grassSVN/grass/trunk/raster/r.watershed/seg/do_astar.c cmp_pnt
File :/raster/r.watershed/seg/over_cells.c
Function
overland_cells_recursive(Begins at: 4, Ends at:36)
Complexity: | 5 | | OK | 5 |
ParamNBR: | 5 | * | WARNING | 5 |
CalledNBR: | 4 | | OK | 4 |
LOC: | 33 | | OK | 33 |
overland_cells(Begins at: 39, Ends at:93)
Complexity: | 7 | | OK | 7 |
CalledNBR: | 7 | | OK | 7 |
LOC: | 55 | | OK | 55 |
Clone analysis:
In /data/project-manager/grass/grassSVN/grass/trunk/raster/r.watershed/seg/over_cells.c clones of overland_cells are:
/var/project-manager/grass/grassSVN/grass/trunk/raster/r.watershed/seg/over_cells.c overland_cells
File :/raster/r.watershed/seg/close_maps.c
Function
close_maps(Begins at: 5, Ends at:165)
Complexity: | 21 | * | WARNING | 21 |
CalledNBR: | 69 | *** | MONSTER | 69 |
LOC: | 161 | ** | BABY-MONSTER | 161 |
Clone analysis:
File :/raster/r.watershed/seg/Gwater.h
The system don't find class, method and function
in this file during analysis!
File :/raster/r.watershed/seg/no_stream.c
Function
no_stream(Begins at: 3, Ends at:116)
Complexity: | 27 | ** | BABY-MONSTER | 27 |
CalledNBR: | 14 | | OK | 14 |
LOC: | 114 | * | WARNING | 114 |
Clone analysis:
File :/raster/r.watershed/seg/split_str.c
Function
split_stream(Begins at: 3, Ends at:94)
Complexity: | 20 | * | WARNING | 20 |
ParamNBR: | 8 | ** | BABY-MONSTER | 8 |
CalledNBR: | 13 | | OK | 13 |
LOC: | 92 | * | WARNING | 92 |
Clone analysis:
File :/raster/r.watershed/seg/cseg_put.c
Function
cseg_put(Begins at: 5, Ends at:12)
Complexity: | 2 | | OK | 2 |
ParamNBR: | 4 | * | WARNING | 4 |
CalledNBR: | 2 | | OK | 2 |
LOC: | 8 | | OK | 8 |
cseg_put_row(Begins at: 14, Ends at:21)
Clone analysis:
File :/raster/r.watershed/seg/dseg_put.c
Function
dseg_put(Begins at: 5, Ends at:12)
dseg_put_row(Begins at: 14, Ends at:21)
Clone analysis:
File :/raster/r.watershed/seg/find_pour.c
Function
find_pourpts(Begins at: 3, Ends at:52)
CalledNBR: | 11 | | OK | 11 |
LOC: | 50 | | OK | 50 |
metrics are OK
Clone analysis:
File :/raster/r.watershed/seg/bseg_put.c
Function
bseg_put_row(Begins at: 14, Ends at:21)
bseg_put(Begins at: 5, Ends at:12)
bseg_put_old(Begins at: 23, Ends at:40)
LOC: | 18 | | OK | 18 |
Clone analysis:
File :/raster/r.watershed/seg/init_vars.c
Function
init_vars(Begins at: 10, Ends at:585)
Complexity: | 104 | *** | MONSTER | 104 |
CalledNBR: | 164 | *** | MONSTER | 164 |
LOC: | 576 | *** | MONSTER | 576 |
Clone analysis:
File :/raster/r.watershed/seg/sseg_put.c
Function
Clone analysis:
File :/raster/r.watershed/seg/slope_len.c
Function
slope_length(Begins at: 3, Ends at:56)
Complexity: | 10 | * | WARNING | 10 |
CalledNBR: | 9 | | OK | 9 |
LOC: | 54 | | OK | 54 |
at least 2 values are close to an outlier please consider revising code!
Clone analysis:
File :/raster/r.watershed/seg/cseg.h
File :/raster/r.watershed/seg/sseg_get.c
Function
seg_get(Begins at: 5, Ends at:12)
seg_get_row(Begins at: 14, Ends at:21)
seg_flush(Begins at: 23, Ends at:27)
LOC: | 5 | | OK | 5 |
metrics are OK
Clone analysis:
File :/raster/r.watershed/seg/def_basin.c
Function
def_basin(Begins at: 3, Ends at:107)
LOC: | 105 | * | WARNING | 105 |
Clone analysis:
____________________________________________
Threshold grass key metrics values at Fri Dec 17 06:22:54 EST 2010 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 10 | 22 | 34 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 18 | 43 | 69 |
LOC: | 68 | 153 | 239 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
