[GRASS-QA] GRASS QA: martinl |args.c dig_structs.h gisdefs.h link.c
...| 4 clones | 0 monsters |13 warnings
soccerlab.info at gmail.com
Sun Dec 19 15:27:54 EST 2010
Hello martinl,
here's a report on your recent grass-SVN change for the revision : 44630
ANALYSIS
your changes to files/class/methods/functions :
File :/vector/v.external.out/args.c
Function
parse_args(Begins at: 8, Ends at:51)
| New Metrics |Old Metrics|
Complexity: | 2 | | OK | 2 |
ParamNBR: | 4 | * | WARNING | 4 |
CalledNBR: | 17 | | OK | 17 |
LOC: | 44 | | OK | 44 |
Conclusion: | this function is a WARNING |
at least 1 values are close to an outlier please consider revising code!
Clone analysis:
This file does not contain cloned functions
File :/include/vect/dig_structs.h
Class
Cat_index(Begins at: 224, Ends at:237)
| DIT | NOC | WMC | RFC | CBO | LCOM |
|NEW Metrics | 1 | 0 | 0 | 1 | 0 | 0 |
|OLD Metrics | 1 | 0 | 0 | 1 | 0 | 0 |
Class
Coor_info(Begins at: 158, Ends at:162)
|NEW Metrics | 1 | 0 | 0 | 0 | 0 | 0 |
|OLD Metrics | 1 | 0 | 0 | 0 | 0 | 0 |
Class
Format_info(Begins at: 217, Ends at:221)
Class
Format_info_ogr(Begins at: 168, Ends at:214)
Class
Map_info(Begins at: 384, Ends at:452)
Class
P_area(Begins at: 498, Ends at:518)
Class
P_isle(Begins at: 521, Ends at:537)
Class
P_line(Begins at: 475, Ends at:495)
Class
P_node(Begins at: 455, Ends at:472)
Class
Plus_head(Begins at: 240, Ends at:381)
Class
Port_info(Begins at: 90, Ends at:111)
Class
bound_box(Begins at: 48, Ends at:56)
Class
cat_list(Begins at: 559, Ends at:566)
Class
dblinks(Begins at: 82, Ends at:87)
Class
dig_head(Begins at: 124, Ends at:155)
Class
field_info(Begins at: 71, Ends at:79)
Class
gvfile(Begins at: 59, Ends at:68)
Class
ilist(Begins at: 572, Ends at:577)
Class
line_cats(Begins at: 550, Ends at:556)
Class
line_pnts(Begins at: 540, Ends at:547)
Class
recycle(Begins at: 118, Ends at:121)
Class
site_att(Begins at: 40, Ends at:45)
Class
spatial_index(Begins at: 588, Ends at:592)
Class
varray(Begins at: 580, Ends at:585)
Clone analysis:
File :/include/gisdefs.h
The system don't find class, method and function
in this file during analysis!
File :/vector/v.external.out/link.c
Function
make_link(Begins at: 7, Ends at:50)
Complexity: | 10 | * | WARNING | 10 |
ParamNBR: | 3 | * | WARNING | 3 |
CalledNBR: | 15 | | OK | 15 |
at least 2 values are close to an outlier please consider revising code!
Clone analysis:
This file has 1 potentially cloned functions:
In /data/project-manager/grass/grassSVN/grass/trunk/vector/v.external.out/link.c clones of make_link are:
/data/project-manager/grass/grassSVN/grass/trunk/raster/r.external.out/main.c make_link
File :/lib/vector/Vlib/close_ogr.c
Function
V1_close_ogr(Begins at: 33, Ends at:63)
Complexity: | 6 | | OK | 6 |
ParamNBR: | 1 | | OK | 1 |
CalledNBR: | 11 | | OK | 11 |
LOC: | 31 | | OK | 31 |
Conclusion: | this function is a OK |
metrics are OK
Clone analysis:
File :/lib/vector/Vlib/close.c
Function
Vect_close(Begins at: 65, Ends at:157)
Complexity: | 12 | * | WARNING | 12 |
CalledNBR: | 37 | * | WARNING | 37 |
LOC: | 93 | * | WARNING | 93 |
at least 3 values are close to an outlier please consider revising code!
Clone analysis:
File :/lib/vector/Vlib/build.c
Function
Vect_build_partial(Begins at: 112, Ends at:235)
Complexity: | 26 | ** | BABY-MONSTER | 26 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 47 | ** | BABY-MONSTER | 47 |
LOC: | 124 | * | WARNING | 124 |
Conclusion: | this function is a BABY-MONSTER |
metric are OUT OF RANGE!
Clone analysis:
In /data/project-manager/grass/grassSVN/grass/trunk/lib/vector/Vlib/build.c clones of Vect_build_partial are:
/var/project-manager/grass/grassSVN/grass/trunk/lib/vector/Vlib/build.c Vect_build_partial
File :/lib/vector/Vlib/open.c
Function
open_new_dummy(Begins at: 40, Ends at:43)
Complexity: | 1 | | OK | 1 |
ParamNBR: | 0 | | OK | 0 |
CalledNBR: | 0 | | OK | 0 |
LOC: | 4 | | OK | 4 |
metrics are OK
Vect_open_new(Begins at: 686, Ends at:812)
Complexity: | 13 | * | WARNING | 13 |
CalledNBR: | 61 | ** | BABY-MONSTER | 61 |
LOC: | 127 | * | WARNING | 127 |
format(Begins at: 46, Ends at:50)
CalledNBR: | 2 | | OK | 2 |
LOC: | 5 | | OK | 5 |
metrics are OK
open_old_dummy(Begins at: 35, Ends at:38)
metrics are OK
fatal_error(Begins at: 87, Ends at:99)
Complexity: | 5 | | OK | 5 |
LOC: | 13 | | OK | 13 |
metrics are OK
Clone analysis:
This file has 2 potentially cloned functions:
fatal_error
In /data/project-manager/grass/grassSVN/grass/trunk/lib/vector/Vlib/open.c clones of Vect_open_new are:
/var/project-manager/grass/grassSVN/grass/trunk/lib/vector/Vlib/open.c Vect_open_new
In /data/project-manager/grass/grassSVN/grass/trunk/lib/vector/Vlib/open.c clones of fatal_error are:
/var/project-manager/grass/grassSVN/grass/trunk/lib/vector/Vlib/open.c fatal_error
File :/vector/v.external.out/local_proto.h
Class
_flags(Begins at: 8, Ends at:10)
Class
_options(Begins at: 4, Ends at:6)
Clone analysis:
File :/lib/gis/overwrite.c
File :/lib/gis/parser.c
Function
G__print_keywords(Begins at: 743, Ends at:759)
Complexity: | 4 | | OK | 4 |
CalledNBR: | 4 | | OK | 4 |
LOC: | 17 | | OK | 17 |
define_keywords(Begins at: 772, Ends at:776)
metrics are OK
G_get_overwrite(Begins at: 767, Ends at:770)
metrics are OK
check_overwrite(Begins at: 1264, Ends at:1347)
Complexity: | 17 | * | WARNING | 17 |
CalledNBR: | 21 | * | WARNING | 21 |
LOC: | 84 | * | WARNING | 84 |
Clone analysis:
File :/vector/v.external.out/status.c
Function
print_status(Begins at: 6, Ends at:35)
Complexity: | 3 | | OK | 3 |
CalledNBR: | 14 | | OK | 14 |
LOC: | 30 | | OK | 30 |
metrics are OK
Clone analysis:
File :/lib/vector/Vlib/write_ogr.c
Function
V2__add_line_to_topo_ogr(Begins at: 36, Ends at:43)
CalledNBR: | 1 | | OK | 1 |
LOC: | 8 | | OK | 8 |
V2_delete_line_ogr(Begins at: 286, Ends at:346)
CalledNBR: | 8 | | OK | 8 |
LOC: | 61 | | OK | 61 |
V1_write_line_ogr(Begins at: 56, Ends at:146)
CalledNBR: | 27 | * | WARNING | 27 |
LOC: | 91 | * | WARNING | 91 |
at least 4 values are close to an outlier please consider revising code!
Clone analysis:
File :/vector/v.external.out/main.c
Function
main(Begins at: 26, Ends at:68)
CalledNBR: | 19 | * | WARNING | 19 |
LOC: | 43 | | OK | 43 |
Clone analysis:
File :/lib/vector/Vlib/open_ogr.c
Function
V1_open_new_ogr(Begins at: 213, Ends at:279)
Complexity: | 9 | | OK | 9 |
CalledNBR: | 22 | * | WARNING | 22 |
LOC: | 67 | | OK | 67 |
V2_open_old_ogr(Begins at: 127, Ends at:201)
Complexity: | 8 | | OK | 8 |
LOC: | 75 | * | WARNING | 75 |
Clone analysis:
File :/include/vector.h
____________________________________________
Threshold grass key metrics values at Sun Dec 19 15:27:38 EST 2010 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 10 | 22 | 34 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 18 | 43 | 69 |
LOC: | 68 | 153 | 239 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
