[GRASS-QA] GRASS QA: martinl |build_ogr.c build.c open.c | 5 clones
| 0 monsters |3 warnings
soccerlab.info at gmail.com
Fri Dec 24 10:14:26 EST 2010
Hello martinl,
here's a report on your recent grass-SVN change for the revision : 44712
ANALYSIS
your changes to files/class/methods/functions :
File :/lib/vector/Vlib/build_ogr.c
Function
add_geometry(Begins at: 167, Ends at:329)
| New Metrics |Old Metrics|
Complexity: | 20 | * | WARNING | 20 |
ParamNBR: | 4 | * | WARNING | 4 |
CalledNBR: | 62 | ** | BABY-MONSTER | 62 |
LOC: | 163 | ** | BABY-MONSTER | 163 |
Conclusion: | this function is a BABY-MONSTER |
metric are OUT OF RANGE!
add_line(Begins at: 123, Ends at:162)
Complexity: | 5 | | OK | 5 |
ParamNBR: | 5 | * | WARNING | 5 |
CalledNBR: | 9 | | OK | 9 |
LOC: | 40 | | OK | 40 |
Conclusion: | this function is a WARNING |
at least 1 values are close to an outlier please consider revising code!
reset_parts(Begins at: 60, Ends at:63)
Complexity: | 1 | | OK | 1 |
ParamNBR: | 1 | | OK | 1 |
CalledNBR: | 0 | | OK | 0 |
LOC: | 4 | | OK | 4 |
Conclusion: | this function is a OK |
metrics are OK
add_part(Begins at: 77, Ends at:87)
Complexity: | 2 | | OK | 2 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 2 | | OK | 2 |
LOC: | 11 | | OK | 11 |
metrics are OK
init_parts(Begins at: 50, Ends at:54)
LOC: | 5 | | OK | 5 |
metrics are OK
add_parts_to_offset(Begins at: 100, Ends at:118)
Complexity: | 3 | | OK | 3 |
CalledNBR: | 3 | | OK | 3 |
LOC: | 19 | | OK | 19 |
metrics are OK
free_parts(Begins at: 68, Ends at:72)
CalledNBR: | 1 | | OK | 1 |
metrics are OK
del_part(Begins at: 92, Ends at:95)
metrics are OK
Clone analysis:
This file has 4 potentially cloned functions:
add_line add_part add_parts_to_offset
In /data/project-manager/grass/grassSVN/grass/trunk/lib/vector/Vlib/build_ogr.c clones of add_geometry are:
/var/project-manager/grass/grassSVN/grass/trunk/lib/vector/Vlib/build_ogr.c add_geometry
In /data/project-manager/grass/grassSVN/grass/trunk/lib/vector/Vlib/build_ogr.c clones of add_line are:
/var/project-manager/grass/grassSVN/grass/trunk/lib/vector/Vlib/build_ogr.c add_line
In /data/project-manager/grass/grassSVN/grass/trunk/lib/vector/Vlib/build_ogr.c clones of add_part are:
/var/project-manager/grass/grassSVN/grass/trunk/lib/vector/Vlib/build_ogr.c add_part
In /data/project-manager/grass/grassSVN/grass/trunk/lib/vector/Vlib/build_ogr.c clones of add_parts_to_offset are:
/var/project-manager/grass/grassSVN/grass/trunk/lib/vector/Vlib/build_ogr.c add_parts_to_offset
File :/lib/vector/Vlib/build.c
Function
Vect_build(Begins at: 53, Ends at:56)
metrics are OK
Vect_build_partial(Begins at: 109, Ends at:236)
Complexity: | 27 | ** | BABY-MONSTER | 27 |
CalledNBR: | 51 | ** | BABY-MONSTER | 51 |
LOC: | 128 | * | WARNING | 128 |
Clone analysis:
This file has 1 potentially cloned functions:
In /data/project-manager/grass/grassSVN/grass/trunk/lib/vector/Vlib/build.c clones of Vect_build_partial are:
/var/project-manager/grass/grassSVN/grass/trunk/lib/vector/Vlib/build.c Vect_build_partial
File :/lib/vector/Vlib/open.c
The system don't find class, method and function
in this file during analysis!
____________________________________________
Threshold grass key metrics values at Fri Dec 24 10:14:18 EST 2010 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 10 | 22 | 34 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 18 | 43 | 69 |
LOC: | 68 | 153 | 239 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
