[GRASS-QA] GRASS QA: martinl |intersect.c break_polygons.c array.c legal_vname.c ...| no clones | 0 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Sat Dec 25 11:31:43 EST 2010
Hello martinl,
here's a report on your recent grass-SVN change for the revision : 44720
ANALYSIS
your changes to files/class/methods/functions :
          File :/lib/vector/Vlib/intersect.c
The system don't find class, method and function
 in this file during analysis!
          File :/lib/vector/Vlib/break_polygons.c
          File :/lib/vector/Vlib/array.c
          File :/lib/vector/Vlib/legal_vname.c
          File :/lib/vector/Vlib/constraint.c
          File :/lib/vector/Vlib/tin.c
          File :/lib/vector/Vlib/error.c
          File :/lib/vector/Vlib/snap.c
          File :/lib/vector/Vlib/poly.c
          Class
Slink(Begins at: 25, Ends at:29)
             |    DIT |    NOC |    WMC |    RFC |    CBO |   LCOM |
|NEW Metrics |      1 |      0 |      0 |      0 |      0 |      0 |
|OLD Metrics |        |        |        |        |        |        |
Clone analysis:
This file does not contain cloned functions
          File :/lib/vector/Vlib/simple_features.c
          File :/lib/vector/Vlib/bridges.c
          File :/lib/vector/Vlib/write_ogr.c
          File :/lib/vector/Vlib/read_nat.c
          File :/lib/vector/Vlib/rewind_nat.c
          File :/lib/vector/Vlib/overlay.c
          File :/lib/vector/Vlib/cindex.c
          File :/lib/vector/Vlib/buffer2.c
          File :/lib/vector/Vlib/buffer.c
          File :/lib/vector/Vlib/overlap.c
          File :/lib/vector/Vlib/close.c
          File :/lib/vector/Vlib/dgraph.c
          Class
intersection_point(Begins at: 35, Ends at:40)
          Class
seg_intersection(Begins at: 42, Ends at:47)
          Class
seg_intersection_list(Begins at: 49, Ends at:54)
          Class
seg_intersections(Begins at: 56, Ends at:64)
Clone analysis:
          File :/lib/vector/Vlib/break_lines.c
          File :/lib/vector/Vlib/map.c
          File :/lib/vector/Vlib/rewind_ogr.c
          File :/lib/vector/Vlib/field.c
          File :/lib/vector/Vlib/hist.c
          File :/lib/vector/Vlib/open.c
          File :/lib/vector/Vlib/read.c
          File :/lib/vector/Vlib/init_head.c
          File :/lib/vector/Vlib/clean_nodes.c
          File :/lib/vector/Vlib/select.c
          File :/lib/vector/Vlib/open_nat.c
          File :/lib/vector/Vlib/find.c
          File :/lib/vector/Vlib/e_intersect.c
          File :/lib/vector/Vlib/close_ogr.c
          File :/lib/vector/Vlib/graph.c
          File :/lib/vector/Vlib/dangles.c
          File :/lib/vector/Vlib/line.c
          File :/lib/vector/Vlib/box.c
          File :/lib/vector/Vlib/ascii.c
          File :/lib/vector/Vlib/remove_duplicates.c
          File :/lib/vector/Vlib/close_nat.c
          File :/lib/vector/Vlib/open_ogr.c
          File :/lib/vector/Vlib/merge_lines.c
          File :/lib/vector/Vlib/net.c
          File :/lib/vector/Vlib/type.c
          File :/lib/vector/Vlib/level_two.c
          File :/lib/vector/Vlib/cats.c
          File :/lib/vector/Vlib/window.c
          File :/lib/vector/Vlib/list.c
          File :/lib/vector/Vlib/remove_areas.c
          File :/lib/vector/Vlib/dbcolumns.c
          File :/lib/vector/Vlib/read_ogr.c
          File :/lib/vector/Vlib/sindex.c
          File :/lib/vector/Vlib/level.c
          File :/lib/vector/Vlib/rewind.c
          File :/lib/vector/Vlib/area.c
          File :/lib/vector/Vlib/build_nat.c
____________________________________________
Threshold grass key metrics values at Sat Dec 25 11:31:34 EST 2010 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |        10 |        22 |        34 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        18 |        43 |        69 |
LOC:                  |        68 |       153 |       239 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
