[GRASS-QA] GRASS QA: martinl |header.c dig_structs.h write_ogr.c build_ogr.c ...| 8 clones | 0 monsters |10 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Sat Dec 25 15:47:08 EST 2010
Hello martinl,
here's a report on your recent grass-SVN change for the revision : 44722
ANALYSIS
your changes to files/class/methods/functions :
          File :/lib/vector/Vlib/header.c
          Function
Vect_get_map_date(Begins at: 480, Ends at:483)
              |          New Metrics           |Old Metrics|
Complexity:   |       1 |       |           OK |         1 |
ParamNBR:     |       1 |       |           OK |         1 |
CalledNBR:    |       0 |       |           OK |         0 |
LOC:          |       4 |       |           OK |         4 |
Conclusion:   | this function is a            OK           |
metrics are OK
Vect_get_ogr_layer_name(Begins at: 270, Ends at:273)
metrics are OK
Vect_write_header(Begins at: 65, Ends at:70)
CalledNBR:    |       1 |       |           OK |         1 |
LOC:          |       6 |       |           OK |         6 |
metrics are OK
Vect_get_ogr_geometry_type(Begins at: 304, Ends at:327)
Complexity:   |       7 |       |           OK |         7 |
CalledNBR:    |      10 |       |           OK |        10 |
LOC:          |      24 |       |           OK |        24 |
metrics are OK
Vect_get_thresh(Begins at: 655, Ends at:659)
LOC:          |       5 |       |           OK |         5 |
metrics are OK
Vect_get_scale(Begins at: 507, Ends at:510)
metrics are OK
Vect_read_header(Begins at: 52, Ends at:56)
metrics are OK
Vect_set_scale(Begins at: 493, Ends at:498)
ParamNBR:     |       2 |       |           OK |         2 |
metrics are OK
Vect_set_date(Begins at: 381, Ends at:387)
CalledNBR:    |       2 |       |           OK |         2 |
LOC:          |       7 |       |           OK |         7 |
metrics are OK
Vect_get_full_name(Begins at: 225, Ends at:249)
Complexity:   |       3 |       |           OK |         3 |
LOC:          |      25 |       |           OK |        25 |
metrics are OK
Vect__read_head(Begins at: 116, Ends at:187)
Complexity:   |      18 |     * |      WARNING |        18 |
CalledNBR:    |      62 |    ** | BABY-MONSTER |        62 |
LOC:          |      72 |     * |      WARNING |        72 |
Conclusion:   | this function is a  BABY-MONSTER           |
 metric are OUT OF RANGE!
Vect_print_header(Begins at: 34, Ends at:43)
CalledNBR:    |       9 |       |           OK |         9 |
LOC:          |      10 |       |           OK |        10 |
metrics are OK
Vect_get_comment(Begins at: 535, Ends at:538)
metrics are OK
Vect_set_thresh(Begins at: 641, Ends at:646)
metrics are OK
Vect_get_proj(Begins at: 598, Ends at:601)
metrics are OK
Vect_set_map_date(Begins at: 465, Ends at:471)
metrics are OK
Vect_get_map_name(Begins at: 452, Ends at:455)
metrics are OK
Vect_set_comment(Begins at: 520, Ends at:526)
metrics are OK
Vect_get_proj_name(Begins at: 615, Ends at:631)
CalledNBR:    |       7 |       |           OK |         7 |
LOC:          |      17 |       |           OK |        17 |
metrics are OK
Vect_get_zone(Begins at: 562, Ends at:565)
metrics are OK
Vect_get_ogr_dsn_name(Begins at: 258, Ends at:261)
metrics are OK
Vect_get_organization(Begins at: 365, Ends at:368)
metrics are OK
Vect_get_date(Begins at: 396, Ends at:399)
metrics are OK
Vect_get_person(Begins at: 424, Ends at:427)
metrics are OK
Vect_set_map_name(Begins at: 437, Ends at:443)
metrics are OK
Vect_is_3d(Begins at: 337, Ends at:340)
metrics are OK
Vect_get_name(Begins at: 196, Ends at:199)
metrics are OK
Vect_set_organization(Begins at: 350, Ends at:356)
metrics are OK
Vect_set_proj(Begins at: 581, Ends at:586)
metrics are OK
Vect_set_zone(Begins at: 548, Ends at:553)
metrics are OK
Vect_set_person(Begins at: 409, Ends at:415)
metrics are OK
Vect_get_mapset(Begins at: 208, Ends at:211)
metrics are OK
Vect_get_ogr_format_info(Begins at: 285, Ends at:294)
Complexity:   |       2 |       |           OK |         2 |
CalledNBR:    |       3 |       |           OK |         3 |
metrics are OK
Vect__write_head(Begins at: 80, Ends at:106)
CalledNBR:    |      24 |     * |      WARNING |        24 |
LOC:          |      27 |       |           OK |        27 |
Conclusion:   | this function is a       WARNING           |
 at least 1 values are close to an outlier please consider revising code!
lookup(Begins at: 663, Ends at:669)
ParamNBR:     |       4 |     * |      WARNING |         4 |
Clone analysis:
This file has 5 potentially cloned functions:
  Vect_print_header  Vect_get_proj_name  Vect_get_ogr_format_info  Vect__write_head
In /data/project-manager/grass/grassSVN/grass/trunk/lib/vector/Vlib/header.c clones of Vect_get_full_name are:
          /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/Vlib/header.c  Vect_get_full_name
In /data/project-manager/grass/grassSVN/grass/trunk/lib/vector/Vlib/header.c clones of Vect_print_header are:
          /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/Vlib/header.c  Vect_print_header
In /data/project-manager/grass/grassSVN/grass/trunk/lib/vector/Vlib/header.c clones of Vect_get_proj_name are:
          /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/Vlib/header.c  Vect_get_proj_name
In /data/project-manager/grass/grassSVN/grass/trunk/lib/vector/Vlib/header.c clones of Vect_get_ogr_format_info are:
          /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/Vlib/header.c  Vect_get_ogr_format_info
In /data/project-manager/grass/grassSVN/grass/trunk/lib/vector/Vlib/header.c clones of Vect__write_head are:
          /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/Vlib/header.c  Vect__write_head
          File :/include/vect/dig_structs.h
          Class
Cat_index(Begins at: 227, Ends at:240)
             |    DIT |    NOC |    WMC |    RFC |    CBO |   LCOM |
|NEW Metrics |      1 |      0 |      0 |      1 |      0 |      0 |
|OLD Metrics |      1 |      0 |      0 |      1 |      0 |      0 |
          Class
Coor_info(Begins at: 158, Ends at:162)
|NEW Metrics |      1 |      0 |      0 |      0 |      0 |      0 |
|OLD Metrics |      1 |      0 |      0 |      0 |      0 |      0 |
          Class
Format_info(Begins at: 220, Ends at:224)
          Class
Format_info_ogr(Begins at: 168, Ends at:217)
          Class
Map_info(Begins at: 387, Ends at:455)
          Class
P_area(Begins at: 501, Ends at:521)
          Class
P_isle(Begins at: 524, Ends at:540)
          Class
P_line(Begins at: 478, Ends at:498)
          Class
P_node(Begins at: 458, Ends at:475)
          Class
Plus_head(Begins at: 243, Ends at:384)
          Class
Port_info(Begins at: 90, Ends at:111)
          Class
bound_box(Begins at: 48, Ends at:56)
          Class
cat_list(Begins at: 562, Ends at:569)
          Class
dblinks(Begins at: 82, Ends at:87)
          Class
dig_head(Begins at: 124, Ends at:155)
          Class
field_info(Begins at: 71, Ends at:79)
          Class
gvfile(Begins at: 59, Ends at:68)
          Class
ilist(Begins at: 575, Ends at:580)
          Class
line_cats(Begins at: 553, Ends at:559)
          Class
line_pnts(Begins at: 543, Ends at:550)
          Class
recycle(Begins at: 118, Ends at:121)
          Class
site_att(Begins at: 40, Ends at:45)
          Class
spatial_index(Begins at: 591, Ends at:595)
          Class
varray(Begins at: 583, Ends at:588)
Clone analysis:
This file does not contain cloned functions
          File :/lib/vector/Vlib/write_ogr.c
          Function
V1_write_line_ogr(Begins at: 56, Ends at:146)
Complexity:   |      13 |     * |      WARNING |        13 |
CalledNBR:    |      26 |     * |      WARNING |        26 |
LOC:          |      91 |     * |      WARNING |        91 |
 at least 4 values are close to an outlier please consider revising code!
Clone analysis:
          File :/lib/vector/Vlib/build_ogr.c
          Function
Vect_build_ogr(Begins at: 340, Ends at:431)
Complexity:   |       8 |       |           OK |         8 |
CalledNBR:    |      37 |     * |      WARNING |        37 |
LOC:          |      92 |     * |      WARNING |        92 |
 at least 2 values are close to an outlier please consider revising code!
Clone analysis:
This file has 1 potentially cloned functions:
In /data/project-manager/grass/grassSVN/grass/trunk/lib/vector/Vlib/build_ogr.c clones of Vect_build_ogr are:
          /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/Vlib/build_ogr.c  Vect_build_ogr
          File :/lib/vector/Vlib/open_ogr.c
          Function
V2_open_new_ogr(Begins at: 284, Ends at:341)
Complexity:   |      11 |     * |      WARNING |        11 |
CalledNBR:    |      14 |       |           OK |        14 |
LOC:          |      58 |       |           OK |        58 |
V1_open_new_ogr(Begins at: 216, Ends at:271)
ParamNBR:     |       3 |     * |      WARNING |         3 |
CalledNBR:    |      20 |     * |      WARNING |        20 |
LOC:          |      56 |       |           OK |        56 |
V2_open_old_ogr(Begins at: 128, Ends at:202)
CalledNBR:    |      22 |     * |      WARNING |        22 |
LOC:          |      75 |     * |      WARNING |        75 |
Clone analysis:
          File :/lib/vector/Vlib/build.c
          Function
Vect_build_partial(Begins at: 109, Ends at:232)
Complexity:   |      26 |    ** | BABY-MONSTER |        26 |
CalledNBR:    |      47 |    ** | BABY-MONSTER |        47 |
LOC:          |     124 |     * |      WARNING |       124 |
Clone analysis:
In /data/project-manager/grass/grassSVN/grass/trunk/lib/vector/Vlib/build.c clones of Vect_build_partial are:
          /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/Vlib/build.c  Vect_build_partial
          File :/lib/vector/Vlib/open.c
          Function
Vect_open_new(Begins at: 686, Ends at:814)
CalledNBR:    |      63 |    ** | BABY-MONSTER |        63 |
LOC:          |     129 |     * |      WARNING |       129 |
Clone analysis:
In /data/project-manager/grass/grassSVN/grass/trunk/lib/vector/Vlib/open.c clones of Vect_open_new are:
          /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/Vlib/open.c  Vect_open_new
          File :/include/vector.h
The system don't find class, method and function
 in this file during analysis!
____________________________________________
Threshold grass key metrics values at Sat Dec 25 15:46:56 EST 2010 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         9 |        19 |        30 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        17 |        41 |        65 |
LOC:                  |        66 |       148 |       231 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
