[GRASS-QA] GRASS QA: martinl |header.c local_proto.h list.c main.c ...| 1 clones | 1 monsters |5 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Thu Dec 30 11:55:47 EST 2010
Hello martinl,
here's a report on your recent grass-SVN change for the revision : 44811
ANALYSIS
your changes to files/class/methods/functions :
          File :/lib/vector/Vlib/header.c
          Function
Vect_get_ogr_geometry_type(Begins at: 304, Ends at:353)
              |          New Metrics           |Old Metrics|
Complexity:   |      20 |    ** | BABY-MONSTER |        20 |
ParamNBR:     |       1 |       |           OK |         1 |
CalledNBR:    |      36 |     * |      WARNING |        36 |
LOC:          |      50 |       |           OK |        50 |
Conclusion:   | this function is a  BABY-MONSTER           |
 metric are OUT OF RANGE!
Clone analysis:
This file does not contain cloned functions
          File :/vector/v.external/local_proto.h
          Class
_flags(Begins at: 8, Ends at:10)
             |    DIT |    NOC |    WMC |    RFC |    CBO |   LCOM |
|NEW Metrics |      1 |      0 |      0 |      0 |      0 |      0 |
|OLD Metrics |        |        |        |        |        |        |
          Class
_options(Begins at: 4, Ends at:6)
Clone analysis:
          File :/vector/v.external/list.c
          Function
list_layers(Begins at: 20, Ends at:75)
Complexity:   |      17 |     * |      WARNING |        17 |
ParamNBR:     |       4 |     * |      WARNING |         4 |
CalledNBR:    |      13 |       |           OK |        13 |
LOC:          |      56 |       |           OK |        56 |
Conclusion:   | this function is a       WARNING           |
 at least 2 values are close to an outlier please consider revising code!
list_formats(Begins at: 8, Ends at:18)
Complexity:   |       2 |       |           OK |         2 |
CalledNBR:    |       6 |       |           OK |         6 |
LOC:          |      11 |       |           OK |        11 |
Conclusion:   | this function is a            OK           |
metrics are OK
Clone analysis:
          File :/vector/v.external/main.c
          Function
main(Begins at: 32, Ends at:121)
Complexity:   |      10 |     * |      WARNING |        10 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |      51 |    ** | BABY-MONSTER |        51 |
LOC:          |      90 |     * |      WARNING |        90 |
Clone analysis:
          File :/raster/r.external/main.c
          Class
band_info(Begins at: 36, Ends at:44)
|OLD Metrics |      1 |      0 |      0 |      0 |      0 |      0 |
          Function
list_formats(Begins at: 51, Ends at:76)
Complexity:   |       4 |       |           OK |         4 |
CalledNBR:    |       9 |       |           OK |         9 |
LOC:          |      26 |       |           OK |        26 |
metrics are OK
Clone analysis:
          File :/lib/vector/Vlib/open_ogr.c
          Function
V1_open_old_ogr(Begins at: 45, Ends at:122)
Complexity:   |      16 |     * |      WARNING |        16 |
CalledNBR:    |      20 |     * |      WARNING |        20 |
LOC:          |      78 |     * |      WARNING |        78 |
 at least 3 values are close to an outlier please consider revising code!
V1_open_new_ogr(Begins at: 220, Ends at:275)
Complexity:   |       7 |       |           OK |         7 |
ParamNBR:     |       3 |     * |      WARNING |         3 |
Clone analysis:
          File :/lib/vector/Vlib/open.c
          Function
Vect__open_old(Begins at: 152, Ends at:495)
Complexity:   |      44 |   *** |      MONSTER |        44 |
ParamNBR:     |       6 |    ** | BABY-MONSTER |         6 |
CalledNBR:    |     130 |   *** |      MONSTER |       130 |
LOC:          |     344 |   *** |      MONSTER |       344 |
Conclusion:   | this function is a       MONSTER           |
Clone analysis:
This file has 1 potentially cloned functions:
In /data/project-manager/grass/grassSVN/grass/trunk/lib/vector/Vlib/open.c clones of Vect__open_old are:
          /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/Vlib/open.c  Vect__open_old
____________________________________________
Threshold grass key metrics values at Thu Dec 30 11:55:37 EST 2010 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         9 |        19 |        30 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        17 |        41 |        65 |
LOC:                  |        66 |       148 |       231 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
