[GRASS-QA] GRASS QA: martinl |main.c args.c lights.c local_proto.h
...| no clones | 1 monsters |9 warnings
soccerlab.info at gmail.com
Sat Jul 10 14:47:03 EDT 2010
Hello martinl,
here's a report on your recent grass-SVN change for the revision : 42607
ANALYSIS
your changes to files/class/methods/functions :
File :/visualization/nviz2/cmd/main.c
Function
main(Begins at: 30, Ends at:192)
| New Metrics |Old Metrics|
Complexity: | 11 | * | WARNING | 11 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 82 | *** | MONSTER | 82 |
LOC: | 163 | ** | BABY-MONSTER | 163 |
Conclusion: | this function is a MONSTER |
metric are OUT OF RANGE!
Clone analysis:
This file does not contain cloned functions
File :/visualization/nviz2/cmd/args.c
Function
args_viewpoint(Begins at: 438, Ends at:496)
Complexity: | 1 | | OK | 1 |
ParamNBR: | 1 | | OK | 1 |
CalledNBR: | 14 | | OK | 14 |
LOC: | 59 | | OK | 59 |
Conclusion: | this function is a OK |
metrics are OK
args_lighting(Begins at: 564, Ends at:602)
CalledNBR: | 12 | | OK | 12 |
LOC: | 39 | | OK | 39 |
metrics are OK
parse_command(Begins at: 43, Ends at:108)
Complexity: | 2 | | OK | 2 |
ParamNBR: | 3 | * | WARNING | 3 |
CalledNBR: | 21 | * | WARNING | 21 |
LOC: | 66 | | OK | 66 |
Conclusion: | this function is a WARNING |
at least 2 values are close to an outlier please consider revising code!
args_volume(Begins at: 498, Ends at:562)
CalledNBR: | 17 | | OK | 17 |
LOC: | 65 | | OK | 65 |
metrics are OK
args_surface(Begins at: 110, Ends at:299)
CalledNBR: | 57 | ** | BABY-MONSTER | 57 |
LOC: | 190 | ** | BABY-MONSTER | 190 |
Conclusion: | this function is a BABY-MONSTER |
Clone analysis:
File :/lib/nviz/lights.c
Function
Nviz_set_light_bright(Begins at: 62, Ends at:78)
CalledNBR: | 2 | | OK | 2 |
LOC: | 17 | | OK | 17 |
at least 1 values are close to an outlier please consider revising code!
Nviz_set_light_ambient(Begins at: 115, Ends at:128)
ParamNBR: | 5 | * | WARNING | 5 |
LOC: | 14 | | OK | 14 |
Nviz_set_light_color(Begins at: 87, Ends at:106)
LOC: | 20 | | OK | 20 |
Nviz_new_light(Begins at: 167, Ends at:181)
CalledNBR: | 4 | | OK | 4 |
LOC: | 15 | | OK | 15 |
metrics are OK
Nviz_set_light_position(Begins at: 27, Ends at:53)
ParamNBR: | 6 | ** | BABY-MONSTER | 6 |
CalledNBR: | 3 | | OK | 3 |
LOC: | 27 | | OK | 27 |
Clone analysis:
File :/visualization/nviz2/cmd/local_proto.h
Class
GParams(Begins at: 7, Ends at:32)
| DIT | NOC | WMC | RFC | CBO | LCOM |
|NEW Metrics | 1 | 0 | 0 | 0 | 0 | 0 |
|OLD Metrics | | | | | | |
Clone analysis:
File :/lib/nviz/draw.c
Function
Nviz_draw_all_vect(Begins at: 116, Ends at:134)
ParamNBR: | 0 | | OK | 0 |
CalledNBR: | 5 | | OK | 5 |
LOC: | 19 | | OK | 19 |
metrics are OK
Nviz_draw_all_site(Begins at: 141, Ends at:163)
CalledNBR: | 7 | | OK | 7 |
LOC: | 23 | | OK | 23 |
metrics are OK
Nviz_draw_all_vol(Begins at: 170, Ends at:192)
metrics are OK
Nviz_draw_all(Begins at: 199, Ends at:239)
Complexity: | 5 | | OK | 5 |
CalledNBR: | 9 | | OK | 9 |
LOC: | 41 | | OK | 41 |
metrics are OK
Clone analysis:
File :/lib/nviz/change_view.c
Function
Nviz_set_viewpoint_twist(Begins at: 185, Ends at:192)
CalledNBR: | 1 | | OK | 1 |
LOC: | 8 | | OK | 8 |
metrics are OK
Nviz_set_viewpoint_position(Begins at: 93, Ends at:125)
Complexity: | 3 | | OK | 3 |
LOC: | 33 | | OK | 33 |
metrics are OK
Nviz_set_viewpoint_persp(Begins at: 165, Ends at:175)
LOC: | 11 | | OK | 11 |
metrics are OK
Nviz_set_viewpoint_height(Begins at: 135, Ends at:155)
LOC: | 21 | | OK | 21 |
metrics are OK
Nviz_change_exag(Begins at: 202, Ends at:216)
metrics are OK
Clone analysis:
File :/lib/nviz/map_obj.c
Function
Nviz_set_vpoint_attr_default(Begins at: 329, Ends at:339)
metrics are OK
Nviz_set_attr(Begins at: 211, Ends at:300)
Complexity: | 13 | * | WARNING | 13 |
ParamNBR: | 7 | ** | BABY-MONSTER | 7 |
LOC: | 90 | * | WARNING | 90 |
Nviz_new_map_obj(Begins at: 44, Ends at:196)
Complexity: | 24 | ** | BABY-MONSTER | 24 |
ParamNBR: | 4 | * | WARNING | 4 |
CalledNBR: | 51 | ** | BABY-MONSTER | 51 |
LOC: | 153 | * | WARNING | 153 |
Clone analysis:
File :/lib/nviz/position.c
Function
Nviz_init_view(Begins at: 23, Ends at:39)
CalledNBR: | 10 | | OK | 10 |
metrics are OK
Clone analysis:
File :/include/nviz.h
Class
render_window(Begins at: 123, Ends at:139)
Clone analysis:
File :/lib/nviz/exag.c
Function
Nviz_get_exag_height(Begins at: 28, Ends at:64)
Complexity: | 8 | | OK | 8 |
LOC: | 37 | | OK | 37 |
Nviz_get_exag(Begins at: 73, Ends at:95)
Complexity: | 6 | | OK | 6 |
metrics are OK
Clone analysis:
____________________________________________
Threshold grass key metrics values at Sat Jul 10 14:46:51 EDT 2010 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 10 | 22 | 34 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 19 | 44 | 70 |
LOC: | 72 | 163 | 255 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
