[GRASS-QA] GRASS QA: martinl |main.c dsply_maps.c local_proto.h
dsply_path.c ...| no clones | 2 monsters |0 warnings
soccerlab.info at gmail.com
Sat Jul 10 15:25:25 EDT 2010
Hello martinl,
here's a report on your recent grass-SVN change for the revision : 42623
ANALYSIS
your changes to files/class/methods/functions :
File :/general/g.mapsets/main.c
Class
_opt(Begins at: 48, Ends at:54)
| DIT | NOC | WMC | RFC | CBO | LCOM |
|NEW Metrics | 1 | 0 | 0 | 0 | 0 | 0 |
|OLD Metrics | | | | | | |
Function
main(Begins at: 33, Ends at:269)
| New Metrics |Old Metrics|
Complexity: | 36 | *** | MONSTER | 36 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 70 | *** | MONSTER | 70 |
LOC: | 237 | ** | BABY-MONSTER | 237 |
Conclusion: | this function is a MONSTER |
metric are OUT OF RANGE!
Clone analysis:
This file does not contain cloned functions
File :/general/g.mapsets/dsply_maps.c
The system don't find class, method and function
in this file during analysis!
File :/general/g.mapsets/local_proto.h
File :/general/g.mapsets/dsply_path.c
File :/general/g.mapsets/list.c
Function
list_accessible_mapsets(Begins at: 30, Ends at:53)
Complexity: | 7 | | OK | 7 |
ParamNBR: | 1 | | OK | 1 |
CalledNBR: | 15 | | OK | 15 |
LOC: | 24 | | OK | 24 |
Conclusion: | this function is a OK |
metrics are OK
list_available_mapsets(Begins at: 7, Ends at:28)
CalledNBR: | 13 | | OK | 13 |
LOC: | 22 | | OK | 22 |
metrics are OK
Clone analysis:
File :/lib/gis/parser_standard_options.c
Function
G_define_standard_option(Begins at: 94, Ends at:484)
Complexity: | 44 | *** | MONSTER | 44 |
CalledNBR: | 55 | ** | BABY-MONSTER | 55 |
LOC: | 391 | *** | MONSTER | 391 |
Clone analysis:
____________________________________________
Threshold grass key metrics values at Sat Jul 10 15:25:14 EDT 2010 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 10 | 22 | 34 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 19 | 44 | 70 |
LOC: | 72 | 163 | 255 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
