[GRASS-QA] GRASS QA: glynn |start.c | no clones | 0 monsters |1
warnings
soccerlab.info at gmail.com
Sat Jul 10 16:36:43 EDT 2010
Hello glynn,
here's a report on your recent grass-SVN change for the revision : 42651
ANALYSIS
your changes to files/class/methods/functions :
File :/lib/db/dbmi_client/start.c
Function
db_start_driver(Begins at: 43, Ends at:170)
| New Metrics |Old Metrics|
Complexity: | 13 | * | WARNING | 13 |
ParamNBR: | 1 | | OK | 1 |
CalledNBR: | 40 | * | WARNING | 40 |
LOC: | 128 | * | WARNING | 128 |
Conclusion: | this function is a WARNING |
at least 3 values are close to an outlier please consider revising code!
Clone analysis:
This file does not contain cloned functions
____________________________________________
Threshold grass key metrics values at Sat Jul 10 16:36:30 EDT 2010 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 10 | 22 | 34 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 19 | 44 | 70 |
LOC: | 72 | 163 | 255 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
