[GRASS-QA] GRASS QA: mmetz |seg_line.c main.c order.c io.c ...| no
clones | 1 monsters |10 warnings
soccerlab.info at gmail.com
Thu Jun 3 07:33:36 EDT 2010
Hello mmetz,
here's a report on your recent grass-SVN change for the revision : 42455
ANALYSIS
your changes to files/class/methods/functions :
File :/raster/r.stream.angle/seg_line.c
Function
do_segments(Begins at: 8, Ends at:360)
| New Metrics |Old Metrics|
Complexity: | 38 | ** | BABY-MONSTER | 38 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 49 | ** | BABY-MONSTER | 49 |
LOC: | 353 | *** | MONSTER | 353 |
Conclusion: | this function is a MONSTER |
metric are OUT OF RANGE!
Clone analysis:
This file does not contain cloned functions
File :/raster/r.stream.angle/main.c
Function
main(Begins at: 28, Ends at:190)
Complexity: | 14 | * | WARNING | 14 |
CalledNBR: | 56 | ** | BABY-MONSTER | 56 |
LOC: | 163 | * | WARNING | 163 |
Conclusion: | this function is a BABY-MONSTER |
Clone analysis:
File :/raster/r.stream.angle/order.c
Function
strahler(Begins at: 6, Ends at:58)
Complexity: | 8 | | OK | 8 |
ParamNBR: | 1 | | OK | 1 |
CalledNBR: | 1 | | OK | 1 |
LOC: | 53 | | OK | 53 |
Conclusion: | this function is a OK |
metrics are OK
horton(Begins at: 108, Ends at:189)
Complexity: | 11 | * | WARNING | 11 |
CalledNBR: | 4 | | OK | 4 |
LOC: | 82 | * | WARNING | 82 |
Conclusion: | this function is a WARNING |
at least 2 values are close to an outlier please consider revising code!
shreeve(Begins at: 60, Ends at:106)
Complexity: | 6 | | OK | 6 |
LOC: | 47 | | OK | 47 |
metrics are OK
hack(Begins at: 191, Ends at:255)
Complexity: | 9 | | OK | 9 |
LOC: | 65 | | OK | 65 |
metrics are OK
Clone analysis:
File :/raster/r.stream.angle/io.c
Function
create_base_maps(Begins at: 37, Ends at:174)
Complexity: | 26 | ** | BABY-MONSTER | 26 |
CalledNBR: | 60 | ** | BABY-MONSTER | 60 |
LOC: | 138 | * | WARNING | 138 |
close_vector(Begins at: 192, Ends at:307)
Complexity: | 10 | | OK | 10 |
ParamNBR: | 0 | | OK | 0 |
CalledNBR: | 38 | * | WARNING | 38 |
LOC: | 116 | * | WARNING | 116 |
stream_number(Begins at: 177, Ends at:189)
Complexity: | 1 | | OK | 1 |
LOC: | 13 | | OK | 13 |
metrics are OK
Clone analysis:
File :/raster/r.stream.angle/global.h
The system don't find class, method and function
in this file during analysis!
File :/raster/r.stream.angle/tangent.c
Function
calc_tangent(Begins at: 13, Ends at:135)
Complexity: | 16 | * | WARNING | 16 |
CalledNBR: | 7 | | OK | 7 |
LOC: | 123 | * | WARNING | 123 |
add_missing_dirs(Begins at: 141, Ends at:194)
LOC: | 54 | | OK | 54 |
metrics are OK
Clone analysis:
File :/raster/r.stream.angle/init.c
Function
calc_dir(Begins at: 282, Ends at:290)
ParamNBR: | 4 | * | WARNING | 4 |
CalledNBR: | 2 | | OK | 2 |
LOC: | 9 | | OK | 9 |
at least 1 values are close to an outlier please consider revising code!
init_streams(Begins at: 29, Ends at:83)
Complexity: | 2 | | OK | 2 |
LOC: | 55 | | OK | 55 |
metrics are OK
calc_length(Begins at: 300, Ends at:353)
Complexity: | 4 | | OK | 4 |
do_cum_length(Begins at: 173, Ends at:254)
CalledNBR: | 3 | | OK | 3 |
cur_orders(Begins at: 256, Ends at:273)
CalledNBR: | 0 | | OK | 0 |
LOC: | 18 | | OK | 18 |
metrics are OK
trib_nums(Begins at: 4, Ends at:27)
LOC: | 24 | | OK | 24 |
metrics are OK
calc_drop(Begins at: 292, Ends at:298)
LOC: | 7 | | OK | 7 |
find_nodes(Begins at: 85, Ends at:171)
Complexity: | 17 | * | WARNING | 17 |
CalledNBR: | 11 | | OK | 11 |
LOC: | 87 | * | WARNING | 87 |
Clone analysis:
____________________________________________
Threshold grass key metrics values at Thu Jun 03 07:33:31 EDT 2010 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 11 | 26 | 41 |
ParamNBR: | 4 | 8 | 13 |
CalledNBR: | 21 | 49 | 78 |
LOC: | 79 | 181 | 283 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
