[GRASS-QA] GRASS QA: hamish |main.c | no clones | 0 monsters |1 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Tue Jun 8 09:15:35 EDT 2010
Hello hamish,
here's a report on your recent grass-SVN change for the revision : 42509
ANALYSIS
your changes to files/class/methods/functions :
          File :/display/d.rast/main.c
          Function
main(Begins at: 36, Ends at:111)
              |          New Metrics           |Old Metrics|
Complexity:   |       6 |       |           OK |         6 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |      31 |     * |      WARNING |        31 |
LOC:          |      76 |       |           OK |        76 |
Conclusion:   | this function is a       WARNING           |
 at least 1 values are close to an outlier please consider revising code!
Clone analysis:
This file does not contain cloned functions
____________________________________________
Threshold grass key metrics values at Tue Jun 08 09:15:29 EDT 2010 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |        11 |        24 |        38 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        21 |        49 |        78 |
LOC:                  |        79 |       181 |       283 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
