[GRASS-QA] GRASS QA: mmetz |parse.c main.c local_proto.h | no
clones | 1 monsters |1 warnings
soccerlab.info at gmail.com
Thu May 20 15:50:16 EDT 2010
Hello mmetz,
here's a report on your recent grass-SVN change for the revision : 42313
ANALYSIS
your changes to files/class/methods/functions :
File :/vector/v.info/parse.c
Function
parse_args(Begins at: 6, Ends at:54)
| New Metrics |Old Metrics|
Complexity: | 2 | | OK | 2 |
ParamNBR: | 9 | *** | MONSTER | 9 |
CalledNBR: | 21 | | OK | 21 |
LOC: | 49 | | OK | 49 |
Conclusion: | this function is a MONSTER |
metric are OUT OF RANGE!
Clone analysis:
This file does not contain cloned functions
File :/vector/v.info/main.c
Function
main(Begins at: 25, Ends at:92)
Complexity: | 11 | * | WARNING | 11 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 28 | * | WARNING | 28 |
LOC: | 68 | | OK | 68 |
Conclusion: | this function is a WARNING |
at least 2 values are close to an outlier please consider revising code!
Clone analysis:
File :/vector/v.info/local_proto.h
The system don't find class, method and function
in this file during analysis!
____________________________________________
Threshold grass key metrics values at Thu May 20 15:50:04 EDT 2010 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 11 | 24 | 38 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 23 | 54 | 86 |
LOC: | 80 | 183 | 287 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
