[GRASS-QA] GRASS QA: mmetz |open_nat.c open.c | 3 clones | 0 monsters |1 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Thu May 20 16:19:05 EDT 2010
Hello mmetz,
here's a report on your recent grass-SVN change for the revision : 42321
ANALYSIS
your changes to files/class/methods/functions :
          File :/lib/vector/Vlib/open_nat.c
          Function
V1_open_old_nat(Begins at: 40, Ends at:81)
              |          New Metrics           |Old Metrics|
Complexity:   |       5 |       |           OK |         5 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |      13 |       |           OK |        13 |
LOC:          |      42 |       |           OK |        42 |
Conclusion:   | this function is a            OK           |
metrics are OK
V1_open_new_nat(Begins at: 93, Ends at:140)
ParamNBR:     |       3 |       |           OK |         3 |
CalledNBR:    |      17 |       |           OK |        17 |
LOC:          |      48 |       |           OK |        48 |
metrics are OK
check_coor(Begins at: 143, Ends at:163)
Complexity:   |       3 |       |           OK |         3 |
ParamNBR:     |       1 |       |           OK |         1 |
CalledNBR:    |       5 |       |           OK |         5 |
LOC:          |      21 |       |           OK |        21 |
metrics are OK
Clone analysis:
This file does not contain cloned functions
          File :/lib/vector/Vlib/open.c
          Function
Vect_open_sidx(Begins at: 958, Ends at:1047)
Complexity:   |      11 |     * |      WARNING |        11 |
LOC:          |      90 |     * |      WARNING |        90 |
Conclusion:   | this function is a       WARNING           |
 at least 2 values are close to an outlier please consider revising code!
Vect_coor_info(Begins at: 772, Ends at:812)
Complexity:   |       7 |       |           OK |         7 |
CalledNBR:    |      10 |       |           OK |        10 |
LOC:          |      41 |       |           OK |        41 |
metrics are OK
Vect_open_topo(Begins at: 875, Ends at:947)
CalledNBR:    |      15 |       |           OK |        15 |
LOC:          |      73 |       |           OK |        73 |
metrics are OK
Clone analysis:
This file has 3 potentially cloned functions:
  Vect_coor_info  Vect_open_topo
In /data/project-manager/grass/grassSVN/grass/trunk/lib/vector/Vlib/open.c clones of Vect_open_sidx are:
          /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/Vlib/open.c  Vect_open_sidx
In /data/project-manager/grass/grassSVN/grass/trunk/lib/vector/Vlib/open.c clones of Vect_coor_info are:
          /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/Vlib/open.c  Vect_coor_info
In /data/project-manager/grass/grassSVN/grass/trunk/lib/vector/Vlib/open.c clones of Vect_open_topo are:
          /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/Vlib/open.c  Vect_open_topo
____________________________________________
Threshold grass key metrics values at Thu May 20 16:18:54 EDT 2010 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |        11 |        26 |        41 |
ParamNBR:             |         4 |         8 |        13 |
CalledNBR:            |        21 |        49 |        78 |
LOC:                  |        78 |       178 |       279 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
