[GRASS-QA] GRASS QA: glynn |main.c | no clones | 0 monsters |1
warnings
soccerlab.info at gmail.com
Mon May 24 21:06:17 EDT 2010
Hello glynn,
here's a report on your recent grass-SVN change for the revision : 42344
ANALYSIS
your changes to files/class/methods/functions :
File :/display/d.info/main.c
Function
main(Begins at: 21, Ends at:114)
| New Metrics |Old Metrics|
Complexity: | 10 | | OK | 10 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 44 | * | WARNING | 44 |
LOC: | 94 | * | WARNING | 94 |
Conclusion: | this function is a WARNING |
at least 2 values are close to an outlier please consider revising code!
Clone analysis:
This file does not contain cloned functions
____________________________________________
Threshold grass key metrics values at Mon May 24 21:05:59 EDT 2010 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 11 | 26 | 41 |
ParamNBR: | 4 | 8 | 13 |
CalledNBR: | 21 | 49 | 78 |
LOC: | 78 | 178 | 279 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
