[GRASS-QA] GRASS QA: martinl |main.c args.c write_img.c volume.c
...| no clones | 0 monsters |4 warnings
soccerlab.info at gmail.com
Fri May 28 12:53:37 EDT 2010
Hello martinl,
here's a report on your recent grass-SVN change for the revision : 42365
ANALYSIS
your changes to files/class/methods/functions :
File :/visualization/nviz2/cmd/main.c
The system don't find class, method and function
in this file during analysis!
File :/visualization/nviz2/cmd/args.c
Function
args_vpoint(Begins at: 367, Ends at:434)
| New Metrics |Old Metrics|
Complexity: | 1 | | OK | 1 |
ParamNBR: | 1 | | OK | 1 |
CalledNBR: | 18 | | OK | 18 |
LOC: | 68 | | OK | 68 |
Conclusion: | this function is a OK |
metrics are OK
parse_command(Begins at: 42, Ends at:104)
Complexity: | 2 | | OK | 2 |
ParamNBR: | 3 | | OK | 3 |
CalledNBR: | 20 | | OK | 20 |
LOC: | 63 | | OK | 63 |
metrics are OK
args_vline(Begins at: 299, Ends at:365)
LOC: | 67 | | OK | 67 |
metrics are OK
args_volume(Begins at: 496, Ends at:560)
CalledNBR: | 17 | | OK | 17 |
LOC: | 65 | | OK | 65 |
metrics are OK
opt_get_num_answers(Begins at: 569, Ends at:582)
Complexity: | 3 | | OK | 3 |
CalledNBR: | 0 | | OK | 0 |
LOC: | 14 | | OK | 14 |
metrics are OK
check_parameters(Begins at: 589, Ends at:715)
Complexity: | 14 | * | WARNING | 14 |
CalledNBR: | 50 | ** | BABY-MONSTER | 50 |
LOC: | 127 | * | WARNING | 127 |
Conclusion: | this function is a BABY-MONSTER |
metric are OUT OF RANGE!
args_surface(Begins at: 106, Ends at:297)
CalledNBR: | 57 | ** | BABY-MONSTER | 57 |
LOC: | 192 | ** | BABY-MONSTER | 192 |
Clone analysis:
This file does not contain cloned functions
File :/visualization/nviz2/cmd/write_img.c
Function
write_img(Begins at: 30, Ends at:42)
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 2 | | OK | 2 |
LOC: | 13 | | OK | 13 |
metrics are OK
Clone analysis:
File :/visualization/nviz2/cmd/volume.c
Function
load_rasters3d(Begins at: 30, Ends at:51)
CalledNBR: | 6 | | OK | 6 |
LOC: | 22 | | OK | 22 |
metrics are OK
Clone analysis:
File :/visualization/nviz2/cmd/surface.c
Function
surface_set_draw_mode(Begins at: 187, Ends at:262)
Complexity: | 10 | | OK | 10 |
LOC: | 76 | | OK | 76 |
metrics are OK
load_rasters(Begins at: 28, Ends at:180)
Complexity: | 17 | * | WARNING | 17 |
CalledNBR: | 62 | ** | BABY-MONSTER | 62 |
LOC: | 153 | * | WARNING | 153 |
Clone analysis:
File :/visualization/nviz2/cmd/vector.c
Function
load_vpoints(Begins at: 48, Ends at:53)
CalledNBR: | 1 | | OK | 1 |
LOC: | 6 | | OK | 6 |
metrics are OK
vlines_set_attrb(Begins at: 111, Ends at:136)
Complexity: | 5 | | OK | 5 |
CalledNBR: | 7 | | OK | 7 |
LOC: | 26 | | OK | 26 |
metrics are OK
load_vlines(Begins at: 33, Ends at:38)
metrics are OK
vpoints_set_attrb(Begins at: 146, Ends at:185)
CalledNBR: | 15 | | OK | 15 |
LOC: | 40 | | OK | 40 |
metrics are OK
load_vectors(Begins at: 55, Ends at:101)
ParamNBR: | 6 | * | WARNING | 6 |
CalledNBR: | 14 | | OK | 14 |
LOC: | 47 | | OK | 47 |
Conclusion: | this function is a WARNING |
at least 1 values are close to an outlier please consider revising code!
Clone analysis:
____________________________________________
Threshold grass key metrics values at Fri May 28 12:53:27 EDT 2010 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 11 | 26 | 41 |
ParamNBR: | 4 | 8 | 13 |
CalledNBR: | 21 | 49 | 78 |
LOC: | 78 | 178 | 279 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
