[GRASS-QA] GRASS QA: mmetz |read_cell.c contour.h main.c find_con.c | no clones | 0 monsters |2 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Tue Nov 2 11:30:53 EDT 2010
Hello mmetz,
here's a report on your recent grass-SVN change for the revision : 43539
ANALYSIS
your changes to files/class/methods/functions :
          File :/raster/r.surf.contour/read_cell.c
          Function
free_cell(Begins at: 29, Ends at:33)
              |          New Metrics           |Old Metrics|
Complexity:   |       1 |       |           OK |         1 |
ParamNBR:     |       1 |       |           OK |         1 |
CalledNBR:    |       2 |       |           OK |         2 |
LOC:          |       5 |       |           OK |         5 |
Conclusion:   | this function is a            OK           |
metrics are OK
read_cell(Begins at: 5, Ends at:27)
Complexity:   |       2 |       |           OK |         2 |
CalledNBR:    |       9 |       |           OK |         9 |
LOC:          |      23 |       |           OK |        23 |
metrics are OK
Clone analysis:
This file does not contain cloned functions
          File :/raster/r.surf.contour/contour.h
The system don't find class, method and function
 in this file during analysis!
          File :/raster/r.surf.contour/main.c
          Function
main(Begins at: 43, Ends at:130)
Complexity:   |      11 |     * |      WARNING |        11 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |      46 |    ** | BABY-MONSTER |        46 |
LOC:          |      88 |     * |      WARNING |        88 |
Conclusion:   | this function is a  BABY-MONSTER           |
 metric are OUT OF RANGE!
Clone analysis:
          File :/raster/r.surf.contour/find_con.c
          Function
find_con(Begins at: 4, Ends at:75)
Complexity:   |      15 |     * |      WARNING |        15 |
ParamNBR:     |       6 |    ** | BABY-MONSTER |         6 |
CalledNBR:    |      21 |     * |      WARNING |        21 |
LOC:          |      72 |     * |      WARNING |        72 |
Clone analysis:
____________________________________________
Threshold grass key metrics values at Tue Nov 02 11:30:46 EDT 2010 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         9 |        19 |        30 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        17 |        41 |        65 |
LOC:                  |        66 |       150 |       234 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
