[GRASS-QA] GRASS QA: hamish |main.c write.c | 1 clones | 0 monsters
|4 warnings
soccerlab.info at gmail.com
Tue Nov 2 11:51:06 EDT 2010
Hello hamish,
here's a report on your recent grass-SVN change for the revision : 43547
ANALYSIS
your changes to files/class/methods/functions :
File :/raster/r.out.mpeg/main.c
Function
main(Begins at: 91, Ends at:238)
| New Metrics |Old Metrics|
Complexity: | 17 | * | WARNING | 17 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 39 | * | WARNING | 39 |
LOC: | 148 | * | WARNING | 148 |
Conclusion: | this function is a WARNING |
at least 3 values are close to an outlier please consider revising code!
check_encoder(Begins at: 75, Ends at:89)
Complexity: | 1 | | OK | 1 |
ParamNBR: | 1 | | OK | 1 |
CalledNBR: | 3 | | OK | 3 |
LOC: | 15 | | OK | 15 |
Conclusion: | this function is a OK |
metrics are OK
use_r_out(Begins at: 371, Ends at:393)
Complexity: | 3 | | OK | 3 |
CalledNBR: | 7 | | OK | 7 |
LOC: | 23 | | OK | 23 |
metrics are OK
parse_command(Begins at: 474, Ends at:507)
Complexity: | 6 | | OK | 6 |
ParamNBR: | 4 | * | WARNING | 4 |
CalledNBR: | 5 | | OK | 5 |
LOC: | 34 | | OK | 34 |
at least 1 values are close to an outlier please consider revising code!
load_files(Begins at: 241, Ends at:369)
Complexity: | 13 | * | WARNING | 13 |
CalledNBR: | 37 | * | WARNING | 37 |
LOC: | 129 | * | WARNING | 129 |
Clone analysis:
This file has 1 potentially cloned functions:
In /data/project-manager/grass/grassSVN/grass/trunk/raster/r.out.mpeg/main.c clones of parse_command are:
/var/project-manager/grass/grassSVN/grass/trunk/raster/r.out.mpeg/main.c parse_command
File :/raster/r.out.mpeg/write.c
Function
clean_files(Begins at: 327, Ends at:334)
Complexity: | 2 | | OK | 2 |
ParamNBR: | 3 | * | WARNING | 3 |
CalledNBR: | 2 | | OK | 2 |
LOC: | 8 | | OK | 8 |
Clone analysis:
This file does not contain cloned functions
____________________________________________
Threshold grass key metrics values at Tue Nov 02 11:50:58 EDT 2010 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 9 | 19 | 30 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 17 | 41 | 65 |
LOC: | 66 | 150 | 234 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
