[GRASS-QA] GRASS QA: neteler |main.c | no clones | 0 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Tue Nov 2 12:56:48 EDT 2010
Hello neteler,
here's a report on your recent grass-SVN change for the revision : 43575
ANALYSIS
your changes to files/class/methods/functions :
          File :/raster/r.neighbors/main.c
          Class
menu(Begins at: 33, Ends at:42)
             |    DIT |    NOC |    WMC |    RFC |    CBO |   LCOM |
|NEW Metrics |      1 |      0 |      0 |      0 |      0 |      0 |
|OLD Metrics |        |        |        |        |        |        |
Clone analysis:
This file does not contain cloned functions
____________________________________________
Threshold grass key metrics values at Tue Nov 02 12:56:39 EDT 2010 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         9 |        19 |        30 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        17 |        41 |        65 |
LOC:                  |        66 |       150 |       234 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
