[GRASS-QA] GRASS QA: mmetz |ramseg.h ramseg.c main.c local_proto.h ...| no clones | 1 monsters |2 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Tue Nov 2 17:03:56 EDT 2010
Hello mmetz,
here's a report on your recent grass-SVN change for the revision : 43678
ANALYSIS
your changes to files/class/methods/functions :
          File :/grass7/raster/r.clump2/ramseg.h
The system don't find class, method and function
 in this file during analysis!
          File :/grass7/raster/r.clump2/ramseg.c
          Function
seg_index_rc(Begins at: 38, Ends at:48)
              |          New Metrics           |Old Metrics|
Complexity:   |       1 |       |           OK |         1 |
ParamNBR:     |       4 |     * |      WARNING |         4 |
CalledNBR:    |       0 |       |           OK |         0 |
LOC:          |      11 |       |           OK |        11 |
Conclusion:   | this function is a       WARNING           |
 at least 1 values are close to an outlier please consider revising code!
size_array(Begins at: 24, Ends at:35)
ParamNBR:     |       3 |     * |      WARNING |         3 |
LOC:          |      12 |       |           OK |        12 |
Clone analysis:
This file does not contain cloned functions
          File :/grass7/raster/r.clump2/main.c
          Function
main(Begins at: 29, Ends at:373)
Complexity:   |      50 |   *** |      MONSTER |        50 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |     139 |   *** |      MONSTER |       139 |
LOC:          |     345 |   *** |      MONSTER |       345 |
Conclusion:   | this function is a       MONSTER           |
 metric are OUT OF RANGE!
Clone analysis:
          File :/grass7/raster/r.clump2/local_proto.h
          File :/grass7/raster/r.clump2/pq.c
          Function
init_pq(Begins at: 39, Ends at:49)
Complexity:   |       2 |       |           OK |         2 |
ParamNBR:     |       1 |       |           OK |         1 |
CalledNBR:    |       2 |       |           OK |         2 |
Conclusion:   | this function is a            OK           |
metrics are OK
cmp_clump(Begins at: 30, Ends at:37)
Complexity:   |       3 |       |           OK |         3 |
LOC:          |       8 |       |           OK |         8 |
metrics are OK
Clone analysis:
____________________________________________
Threshold grass key metrics values at Tue Nov 02 17:03:46 EDT 2010 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         9 |        19 |        30 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        17 |        41 |        65 |
LOC:                  |        66 |       150 |       234 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
