[GRASS-QA] GRASS QA: ejtizado |algorithm.c | no clones | 0 monsters
|3 warnings
soccerlab.info at gmail.com
Tue Nov 2 17:56:46 EDT 2010
Hello ejtizado,
here's a report on your recent grass-SVN change for the revision : 43699
ANALYSIS
your changes to files/class/methods/functions :
File :/imagery/i.landsat.acca/algorithm.c
Function
acca_second(Begins at: 356, Ends at:460)
| New Metrics |Old Metrics|
Complexity: | 15 | * | WARNING | 15 |
ParamNBR: | 6 | ** | BABY-MONSTER | 6 |
CalledNBR: | 42 | ** | BABY-MONSTER | 42 |
LOC: | 105 | * | WARNING | 105 |
Conclusion: | this function is a BABY-MONSTER |
metric are OUT OF RANGE!
shadow_algorithm(Begins at: 468, Ends at:482)
Complexity: | 2 | | OK | 2 |
ParamNBR: | 1 | | OK | 1 |
CalledNBR: | 0 | | OK | 0 |
LOC: | 15 | | OK | 15 |
Conclusion: | this function is a OK |
metrics are OK
acca_first(Begins at: 209, Ends at:353)
Complexity: | 23 | ** | BABY-MONSTER | 23 |
ParamNBR: | 8 | ** | BABY-MONSTER | 8 |
CalledNBR: | 21 | * | WARNING | 21 |
LOC: | 145 | * | WARNING | 145 |
acca_algorithm(Begins at: 75, Ends at:206)
Complexity: | 11 | * | WARNING | 11 |
ParamNBR: | 5 | * | WARNING | 5 |
CalledNBR: | 26 | * | WARNING | 26 |
LOC: | 132 | * | WARNING | 132 |
Conclusion: | this function is a WARNING |
at least 4 values are close to an outlier please consider revising code!
Clone analysis:
This file does not contain cloned functions
____________________________________________
Threshold grass key metrics values at Tue Nov 02 17:56:35 EDT 2010 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 9 | 19 | 30 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 17 | 41 | 65 |
LOC: | 66 | 150 | 234 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
