[GRASS-QA] GRASS QA: ejtizado |tools.c main.c local_proto.h algorithm.c | no clones | 0 monsters |5 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Tue Nov 2 19:03:32 EDT 2010
Hello ejtizado,
here's a report on your recent grass-SVN change for the revision : 43723
ANALYSIS
your changes to files/class/methods/functions :
          File :/imagery/i.landsat.acca/tools.c
          Function
mean(Begins at: 80, Ends at:95)
              |          New Metrics           |Old Metrics|
Complexity:   |       2 |       |           OK |         2 |
ParamNBR:     |       1 |       |           OK |         1 |
CalledNBR:    |       0 |       |           OK |         0 |
LOC:          |      16 |       |           OK |        16 |
Conclusion:   | this function is a            OK           |
metrics are OK
moment(Begins at: 42, Ends at:77)
Complexity:   |       3 |       |           OK |         3 |
ParamNBR:     |       3 |     * |      WARNING |         3 |
CalledNBR:    |       1 |       |           OK |         1 |
LOC:          |      36 |       |           OK |        36 |
Conclusion:   | this function is a       WARNING           |
 at least 1 values are close to an outlier please consider revising code!
hist_put(Begins at: 26, Ends at:39)
ParamNBR:     |       2 |       |           OK |         2 |
LOC:          |      14 |       |           OK |        14 |
metrics are OK
quantile(Begins at: 98, Ends at:120)
Complexity:   |       4 |       |           OK |         4 |
LOC:          |      23 |       |           OK |        23 |
metrics are OK
Clone analysis:
This file does not contain cloned functions
          File :/imagery/i.landsat.acca/main.c
          Function
check_raster(Begins at: 49, Ends at:82)
Complexity:   |       7 |       |           OK |         7 |
CalledNBR:    |      12 |       |           OK |        12 |
LOC:          |      34 |       |           OK |        34 |
metrics are OK
main(Begins at: 89, Ends at:207)
Complexity:   |       8 |       |           OK |         8 |
CalledNBR:    |      42 |    ** | BABY-MONSTER |        42 |
LOC:          |     119 |     * |      WARNING |       119 |
Conclusion:   | this function is a  BABY-MONSTER           |
 metric are OUT OF RANGE!
Clone analysis:
          File :/imagery/i.landsat.acca/local_proto.h
The system don't find class, method and function
 in this file during analysis!
          File :/imagery/i.landsat.acca/algorithm.c
          Function
acca_algorithm(Begins at: 76, Ends at:200)
Complexity:   |      11 |     * |      WARNING |        11 |
ParamNBR:     |       5 |     * |      WARNING |         5 |
CalledNBR:    |      26 |     * |      WARNING |        26 |
LOC:          |     125 |     * |      WARNING |       125 |
 at least 4 values are close to an outlier please consider revising code!
acca_second(Begins at: 347, Ends at:442)
Complexity:   |      15 |     * |      WARNING |        15 |
ParamNBR:     |       6 |    ** | BABY-MONSTER |         6 |
LOC:          |      96 |     * |      WARNING |        96 |
shadow_algorithm(Begins at: 450, Ends at:459)
LOC:          |      10 |       |           OK |        10 |
metrics are OK
acca_first(Begins at: 203, Ends at:344)
Complexity:   |      23 |    ** | BABY-MONSTER |        23 |
ParamNBR:     |       8 |    ** | BABY-MONSTER |         8 |
CalledNBR:    |      21 |     * |      WARNING |        21 |
LOC:          |     142 |     * |      WARNING |       142 |
Clone analysis:
____________________________________________
Threshold grass key metrics values at Tue Nov 02 19:03:20 EDT 2010 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         9 |        19 |        30 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        17 |        41 |        65 |
LOC:                  |        66 |       150 |       234 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
