[GRASS-QA] GRASS QA: ejtizado |tools.c local_proto.h algorithm.c |
no clones | 1 monsters |3 warnings
soccerlab.info at gmail.com
Tue Nov 2 19:20:00 EDT 2010
Hello ejtizado,
here's a report on your recent grass-SVN change for the revision : 43729
ANALYSIS
your changes to files/class/methods/functions :
File :/imagery/i.landsat.acca/tools.c
Function
quantile(Begins at: 67, Ends at:90)
| New Metrics |Old Metrics|
Complexity: | 4 | | OK | 4 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 0 | | OK | 0 |
LOC: | 24 | | OK | 24 |
Conclusion: | this function is a OK |
metrics are OK
pval(Begins at: 98, Ends at:106)
Complexity: | 2 | | OK | 2 |
CalledNBR: | 1 | | OK | 1 |
LOC: | 9 | | OK | 9 |
metrics are OK
filter_holes(Begins at: 108, Ends at:315)
Complexity: | 31 | *** | MONSTER | 31 |
CalledNBR: | 89 | *** | MONSTER | 89 |
LOC: | 208 | ** | BABY-MONSTER | 208 |
Conclusion: | this function is a MONSTER |
metric are OUT OF RANGE!
moment(Begins at: 42, Ends at:64)
Complexity: | 3 | | OK | 3 |
ParamNBR: | 3 | * | WARNING | 3 |
LOC: | 23 | | OK | 23 |
Conclusion: | this function is a WARNING |
at least 1 values are close to an outlier please consider revising code!
Clone analysis:
This file does not contain cloned functions
File :/imagery/i.landsat.acca/local_proto.h
The system don't find class, method and function
in this file during analysis!
File :/imagery/i.landsat.acca/algorithm.c
Function
acca_algorithm(Begins at: 76, Ends at:204)
Complexity: | 12 | * | WARNING | 12 |
ParamNBR: | 6 | ** | BABY-MONSTER | 6 |
CalledNBR: | 26 | * | WARNING | 26 |
LOC: | 129 | * | WARNING | 129 |
Conclusion: | this function is a BABY-MONSTER |
shadow_algorithm(Begins at: 457, Ends at:472)
ParamNBR: | 1 | | OK | 1 |
LOC: | 16 | | OK | 16 |
metrics are OK
acca_first(Begins at: 207, Ends at:347)
Complexity: | 22 | ** | BABY-MONSTER | 22 |
ParamNBR: | 8 | ** | BABY-MONSTER | 8 |
CalledNBR: | 21 | * | WARNING | 21 |
LOC: | 141 | * | WARNING | 141 |
Clone analysis:
____________________________________________
Threshold grass key metrics values at Tue Nov 02 19:19:49 EDT 2010 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 9 | 19 | 30 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 17 | 41 | 65 |
LOC: | 66 | 150 | 234 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
