[GRASS-QA] GRASS QA: jarekj71 |main.c | no clones | 1 monsters |2
warnings
soccerlab.info at gmail.com
Tue Nov 2 20:28:03 EDT 2010
Hello jarekj71,
here's a report on your recent grass-SVN change for the revision : 43755
ANALYSIS
your changes to files/class/methods/functions :
File :/grass7/raster/r.stream/r.stream.slope/main.c
Function
calculate_difference(Begins at: 262, Ends at:270)
| New Metrics |Old Metrics|
Complexity: | 2 | | OK | 2 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 3 | | OK | 3 |
LOC: | 9 | | OK | 9 |
Conclusion: | this function is a OK |
metrics are OK
calculate_gradient(Begins at: 273, Ends at:293)
CalledNBR: | 4 | | OK | 4 |
LOC: | 21 | | OK | 21 |
metrics are OK
calculate_max_curvature(Begins at: 294, Ends at:339)
Complexity: | 6 | | OK | 6 |
CalledNBR: | 20 | * | WARNING | 20 |
LOC: | 46 | | OK | 46 |
Conclusion: | this function is a WARNING |
at least 1 values are close to an outlier please consider revising code!
calculate_min_curvature(Begins at: 341, Ends at:385)
Complexity: | 5 | | OK | 5 |
LOC: | 45 | | OK | 45 |
main(Begins at: 46, Ends at:260)
Complexity: | 31 | *** | MONSTER | 31 |
CalledNBR: | 83 | *** | MONSTER | 83 |
LOC: | 215 | ** | BABY-MONSTER | 215 |
Conclusion: | this function is a MONSTER |
metric are OUT OF RANGE!
Clone analysis:
This file does not contain cloned functions
____________________________________________
Threshold grass key metrics values at Tue Nov 02 20:27:51 EDT 2010 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 9 | 19 | 30 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 17 | 41 | 65 |
LOC: | 66 | 150 | 234 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
