[GRASS-QA] GRASS QA: ejtizado |tools.c main.c algorithm.c | no clones | 0 monsters |4 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Tue Nov 2 21:43:13 EDT 2010
Hello ejtizado,
here's a report on your recent grass-SVN change for the revision : 43784
ANALYSIS
your changes to files/class/methods/functions :
          File :/imagery/i.landsat.acca/tools.c
          Function
quantile(Begins at: 67, Ends at:90)
              |          New Metrics           |Old Metrics|
Complexity:   |       4 |       |           OK |         4 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |       0 |       |           OK |         0 |
LOC:          |      24 |       |           OK |        24 |
Conclusion:   | this function is a            OK           |
metrics are OK
moment(Begins at: 42, Ends at:64)
Complexity:   |       3 |       |           OK |         3 |
ParamNBR:     |       3 |     * |      WARNING |         3 |
CalledNBR:    |       2 |       |           OK |         2 |
LOC:          |      23 |       |           OK |        23 |
Conclusion:   | this function is a       WARNING           |
 at least 1 values are close to an outlier please consider revising code!
Clone analysis:
This file does not contain cloned functions
          File :/imagery/i.landsat.acca/main.c
          Function
main(Begins at: 91, Ends at:230)
Complexity:   |       9 |     * |      WARNING |         9 |
CalledNBR:    |      53 |    ** | BABY-MONSTER |        53 |
LOC:          |     140 |     * |      WARNING |       140 |
Conclusion:   | this function is a  BABY-MONSTER           |
 metric are OUT OF RANGE!
Clone analysis:
          File :/imagery/i.landsat.acca/algorithm.c
          Function
acca_first(Begins at: 213, Ends at:361)
Complexity:   |      23 |    ** | BABY-MONSTER |        23 |
ParamNBR:     |       8 |    ** | BABY-MONSTER |         8 |
CalledNBR:    |      22 |     * |      WARNING |        22 |
LOC:          |     149 |     * |      WARNING |       149 |
shadow_algorithm(Begins at: 471, Ends at:486)
Complexity:   |       2 |       |           OK |         2 |
ParamNBR:     |       1 |       |           OK |         1 |
LOC:          |      16 |       |           OK |        16 |
metrics are OK
acca_algorithm(Begins at: 75, Ends at:210)
Complexity:   |      12 |     * |      WARNING |        12 |
ParamNBR:     |       6 |    ** | BABY-MONSTER |         6 |
CalledNBR:    |      30 |     * |      WARNING |        30 |
LOC:          |     136 |     * |      WARNING |       136 |
Clone analysis:
____________________________________________
Threshold grass key metrics values at Tue Nov 02 21:43:00 EDT 2010 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         9 |        19 |        30 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        18 |        43 |        69 |
LOC:                  |        67 |       151 |       235 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
