[GRASS-QA] GRASS QA: martinl |main.c main.c main.c | no clones | 1 monsters |2 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Wed Nov 3 01:39:16 EDT 2010
Hello martinl,
here's a report on your recent grass-SVN change for the revision : 43878
ANALYSIS
your changes to files/class/methods/functions :
          File :/display/d.rgb/main.c
          Class
band(Begins at: 28, Ends at:35)
             |    DIT |    NOC |    WMC |    RFC |    CBO |   LCOM |
|NEW Metrics |      1 |      0 |      0 |      0 |      0 |      0 |
|OLD Metrics |        |        |        |        |        |        |
          Function
main(Begins at: 39, Ends at:136)
              |          New Metrics           |Old Metrics|
Complexity:   |      11 |     * |      WARNING |        11 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |      39 |     * |      WARNING |        39 |
LOC:          |      98 |     * |      WARNING |        98 |
Conclusion:   | this function is a       WARNING           |
 at least 3 values are close to an outlier please consider revising code!
Clone analysis:
This file does not contain cloned functions
          File :/display/d.rast/main.c
          Function
main(Begins at: 36, Ends at:113)
Complexity:   |       6 |       |           OK |         6 |
CalledNBR:    |      32 |     * |      WARNING |        32 |
LOC:          |      78 |     * |      WARNING |        78 |
 at least 2 values are close to an outlier please consider revising code!
Clone analysis:
          File :/display/d.vect/main.c
          Function
main(Begins at: 76, Ends at:705)
Complexity:   |      72 |   *** |      MONSTER |        72 |
CalledNBR:    |     200 |   *** |      MONSTER |       200 |
LOC:          |     630 |   *** |      MONSTER |       630 |
Conclusion:   | this function is a       MONSTER           |
 metric are OUT OF RANGE!
Clone analysis:
____________________________________________
Threshold grass key metrics values at Wed Nov 03 01:39:01 EDT 2010 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         9 |        19 |        30 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        18 |        43 |        69 |
LOC:                  |        68 |       153 |       239 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
