[GRASS-QA] GRASS QA: martinl |main.cpp | 5 clones | 1 monsters |3
warnings
soccerlab.info at gmail.com
Wed Nov 3 02:16:35 EDT 2010
Hello martinl,
here's a report on your recent grass-SVN change for the revision : 43893
ANALYSIS
your changes to files/class/methods/functions :
File :/imagery/i.atcorr/main.cpp
Class
IntPair(Begins at: 218, Ends at:232)
| DIT | NOC | WMC | RFC | CBO | LCOM |
|NEW Metrics | 1 | 0 | 5 | 2 | 0 | 1 |
|OLD Metrics | 1 | 0 | 5 | 2 | 0 | 1 |
Class
Options(Begins at: 48, Ends at:67)
|NEW Metrics | 1 | 0 | 0 | 0 | 0 | 0 |
|OLD Metrics | 1 | 0 | 0 | 0 | 0 | 0 |
Class
Position(Begins at: 187, Ends at:193)
|NEW Metrics | 1 | 0 | 2 | 2 | 0 | 1 |
|OLD Metrics | 1 | 0 | 2 | 2 | 0 | 1 |
Class
ScaleRange(Begins at: 69, Ends at:73)
Class
TICache(Begins at: 129, Ends at:161)
|NEW Metrics | 1 | 0 | 8 | 4 | 0 | 2 |
|OLD Metrics | 1 | 0 | 8 | 4 | 0 | 2 |
Class
TIMap(Begins at: 173, Ends at:215)
|NEW Metrics | 1 | 0 | 8 | 7 | 0 | 4 |
|OLD Metrics | 1 | 0 | 8 | 7 | 0 | 4 |
Function
adjust_region(Begins at: 95, Ends at:102)
| New Metrics |Old Metrics|
Complexity: | 1 | | OK | 1 |
ParamNBR: | 1 | | OK | 1 |
CalledNBR: | 2 | | OK | 2 |
LOC: | 8 | | OK | 8 |
Conclusion: | this function is a OK |
metrics are OK
optimize_va(Begins at: 238, Ends at:258)
Complexity: | 2 | | OK | 2 |
ParamNBR: | 4 | * | WARNING | 4 |
CalledNBR: | 6 | | OK | 6 |
LOC: | 21 | | OK | 21 |
Conclusion: | this function is a WARNING |
at least 1 values are close to an outlier please consider revising code!
round_c(Begins at: 106, Ends at:112)
CalledNBR: | 0 | | OK | 0 |
LOC: | 7 | | OK | 7 |
metrics are OK
main(Begins at: 554, Ends at:643)
Complexity: | 15 | * | WARNING | 15 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 34 | * | WARNING | 34 |
LOC: | 90 | * | WARNING | 90 |
at least 3 values are close to an outlier please consider revising code!
write_fp_to_cell(Begins at: 116, Ends at:125)
CalledNBR: | 4 | | OK | 4 |
LOC: | 10 | | OK | 10 |
metrics are OK
define_module(Begins at: 422, Ends at:449)
CalledNBR: | 7 | | OK | 7 |
LOC: | 28 | | OK | 28 |
metrics are OK
process_raster(Begins at: 275, Ends at:407)
Complexity: | 20 | ** | BABY-MONSTER | 20 |
ParamNBR: | 9 | *** | MONSTER | 9 |
CalledNBR: | 42 | * | WARNING | 42 |
LOC: | 133 | * | WARNING | 133 |
Conclusion: | this function is a MONSTER |
metric are OUT OF RANGE!
define_options(Begins at: 453, Ends at:520)
CalledNBR: | 30 | * | WARNING | 30 |
LOC: | 68 | * | WARNING | 68 |
at least 2 values are close to an outlier please consider revising code!
copy_colors(Begins at: 412, Ends at:418)
CalledNBR: | 3 | | OK | 3 |
metrics are OK
read_scale(Begins at: 523, Ends at:551)
Complexity: | 4 | | OK | 4 |
LOC: | 29 | | OK | 29 |
metrics are OK
Clone analysis:
This file has 5 potentially cloned functions:
write_fp_to_cell define_module define_options read_scale
In /data/project-manager/grass/grassSVN/grass/trunk/imagery/i.atcorr/main.cpp clones of optimize_va are:
/var/project-manager/grass/grassSVN/grass/trunk/imagery/i.atcorr/main.cpp optimize_va
In /data/project-manager/grass/grassSVN/grass/trunk/imagery/i.atcorr/main.cpp clones of write_fp_to_cell are:
/var/project-manager/grass/grassSVN/grass/trunk/imagery/i.atcorr/main.cpp write_fp_to_cell
In /data/project-manager/grass/grassSVN/grass/trunk/imagery/i.atcorr/main.cpp clones of define_module are:
/var/project-manager/grass/grassSVN/grass/trunk/imagery/i.atcorr/main.cpp define_module
In /data/project-manager/grass/grassSVN/grass/trunk/imagery/i.atcorr/main.cpp clones of define_options are:
/var/project-manager/grass/grassSVN/grass/trunk/imagery/i.atcorr/main.cpp define_options
In /data/project-manager/grass/grassSVN/grass/trunk/imagery/i.atcorr/main.cpp clones of read_scale are:
/var/project-manager/grass/grassSVN/grass/trunk/imagery/i.atcorr/main.cpp read_scale
____________________________________________
Threshold grass key metrics values at Wed Nov 03 02:16:20 EDT 2010 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 9 | 19 | 30 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 18 | 43 | 69 |
LOC: | 68 | 153 | 239 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
