[GRASS-QA] GRASS QA: ychemin |main.c landsat.h local_proto.h landsat_met.c ...| 23 clones | 1 monsters |10 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Wed Nov 3 06:02:11 EDT 2010
Hello ychemin,
here's a report on your recent grass-SVN change for the revision : 43982
ANALYSIS
your changes to files/class/methods/functions :
          File :/imagery/i.landsat.toar/main.c
          Function
main(Begins at: 29, Ends at:615)
              |          New Metrics           |Old Metrics|
Complexity:   |      68 |   *** |      MONSTER |        68 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |     190 |   *** |      MONSTER |       190 |
LOC:          |     587 |   *** |      MONSTER |       587 |
Conclusion:   | this function is a       MONSTER           |
 metric are OUT OF RANGE!
Clone analysis:
This file does not contain cloned functions
          File :/imagery/i.landsat.toar/landsat.h
The system don't find class, method and function
 in this file during analysis!
          File :/imagery/i.landsat.toar/local_proto.h
          File :/imagery/i.landsat.toar/landsat_met.c
          Function
chrncpy(Begins at: 15, Ends at:22)
Complexity:   |       2 |       |           OK |         2 |
ParamNBR:     |       3 |     * |      WARNING |         3 |
CalledNBR:    |       1 |       |           OK |         1 |
LOC:          |       8 |       |           OK |         8 |
Conclusion:   | this function is a       WARNING           |
 at least 1 values are close to an outlier please consider revising code!
get_value_met(Begins at: 113, Ends at:135)
Complexity:   |       5 |       |           OK |         5 |
CalledNBR:    |       2 |       |           OK |         2 |
LOC:          |      23 |       |           OK |        23 |
get_value_met7(Begins at: 27, Ends at:41)
Complexity:   |       3 |       |           OK |         3 |
LOC:          |      15 |       |           OK |        15 |
met_ETM(Begins at: 43, Ends at:108)
CalledNBR:    |      26 |     * |      WARNING |        26 |
LOC:          |      66 |       |           OK |        66 |
met_TM5(Begins at: 137, Ends at:207)
Complexity:   |      14 |     * |      WARNING |        14 |
CalledNBR:    |      28 |     * |      WARNING |        28 |
LOC:          |      71 |     * |      WARNING |        71 |
 at least 3 values are close to an outlier please consider revising code!
mtl_TM5(Begins at: 224, Ends at:280)
CalledNBR:    |      27 |     * |      WARNING |        27 |
LOC:          |      57 |       |           OK |        57 |
Clone analysis:
This file has 4 potentially cloned functions:
  get_value_met7  met_ETM  met_TM5
In /data/project-manager/grass/grassSVN/grass/trunk/imagery/i.landsat.toar/landsat_met.c clones of get_value_met are:
          /data/project-manager/grass/grassSVN/grass-addons/imagery/i.landsat.toar/landsat_met.c  get_value_met
In /data/project-manager/grass/grassSVN/grass/trunk/imagery/i.landsat.toar/landsat_met.c clones of get_value_met7 are:
          /data/project-manager/grass/grassSVN/grass-addons/imagery/i.landsat.toar/landsat_met.c  get_value_met7
In /data/project-manager/grass/grassSVN/grass/trunk/imagery/i.landsat.toar/landsat_met.c clones of met_ETM are:
          /data/project-manager/grass/grassSVN/grass-addons/imagery/i.landsat.toar/landsat_met.c  met_ETM
In /data/project-manager/grass/grassSVN/grass/trunk/imagery/i.landsat.toar/landsat_met.c clones of met_TM5 are:
          /data/project-manager/grass/grassSVN/grass-addons/imagery/i.landsat.toar/landsat_met.c  met_TM5
          File :/imagery/i.landsat.toar/landsat.c
          Function
lsat_bandctes(Begins at: 51, Ends at:168)
Complexity:   |      11 |     * |      WARNING |        11 |
ParamNBR:     |       7 |    ** | BABY-MONSTER |         7 |
CalledNBR:    |       7 |       |           OK |         7 |
LOC:          |     118 |     * |      WARNING |       118 |
Conclusion:   | this function is a  BABY-MONSTER           |
lsat_qcal2rad(Begins at: 15, Ends at:18)
Complexity:   |       1 |       |           OK |         1 |
CalledNBR:    |       0 |       |           OK |         0 |
LOC:          |       4 |       |           OK |         4 |
Conclusion:   | this function is a            OK           |
metrics are OK
lsat_rad2ref(Begins at: 23, Ends at:26)
metrics are OK
lsat_rad2temp(Begins at: 31, Ends at:34)
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
In /data/project-manager/grass/grassSVN/grass/trunk/imagery/i.landsat.toar/landsat.c clones of lsat_bandctes are:
          /data/project-manager/grass/grassSVN/grass-addons/imagery/i.landsat.toar/landsat.c  lsat_bandctes
          File :/imagery/i.landsat.toar/earth_sun.h
          Class
ln_vsop(Begins at: 11, Ends at:16)
             |    DIT |    NOC |    WMC |    RFC |    CBO |   LCOM |
|NEW Metrics |      1 |      0 |      0 |      0 |      0 |      0 |
|OLD Metrics |        |        |        |        |        |        |
Clone analysis:
          File :/imagery/i.landsat.toar/landsat_set.c
          Function
sensor_ETM(Begins at: 63, Ends at:87)
ParamNBR:     |       1 |       |           OK |         1 |
LOC:          |      25 |       |           OK |        25 |
metrics are OK
sensor_MSS(Begins at: 12, Ends at:36)
metrics are OK
sensor_TM(Begins at: 38, Ends at:61)
LOC:          |      24 |       |           OK |        24 |
metrics are OK
set_ETM(Begins at: 455, Ends at:520)
CalledNBR:    |       4 |       |           OK |         4 |
metrics are OK
set_MSS1(Begins at: 102, Ends at:128)
LOC:          |      27 |       |           OK |        27 |
metrics are OK
set_MSS2(Begins at: 134, Ends at:175)
LOC:          |      42 |       |           OK |        42 |
metrics are OK
set_MSS3(Begins at: 183, Ends at:222)
LOC:          |      40 |       |           OK |        40 |
metrics are OK
set_MSS4(Begins at: 228, Ends at:273)
Complexity:   |       4 |       |           OK |         4 |
CalledNBR:    |       5 |       |           OK |         5 |
LOC:          |      46 |       |           OK |        46 |
metrics are OK
set_MSS5(Begins at: 334, Ends at:378)
LOC:          |      45 |       |           OK |        45 |
metrics are OK
set_TM4(Begins at: 275, Ends at:327)
LOC:          |      53 |       |           OK |        53 |
metrics are OK
set_TM5(Begins at: 380, Ends at:448)
Complexity:   |       9 |     * |      WARNING |         9 |
CalledNBR:    |      10 |       |           OK |        10 |
LOC:          |      69 |     * |      WARNING |        69 |
 at least 2 values are close to an outlier please consider revising code!
Clone analysis:
This file has 14 potentially cloned functions:
  sensor_ETM  sensor_MSS  sensor_MSS  sensor_TM  sensor_TM  set_ETM  set_MSS1  set_MSS1  set_MSS2  set_MSS3  set_MSS4  set_MSS5  set_TM4
In /data/project-manager/grass/grassSVN/grass/trunk/imagery/i.landsat.toar/landsat_set.c clones of sensor_ETM are:
          /data/project-manager/grass/grassSVN/grass-addons/grass7/imagery/i.landsat.toar/landsat_set.c  sensor_ETM
          /data/project-manager/grass/grassSVN/grass-addons/imagery/i.landsat.toar/landsat_set.c  sensor_ETM
In /data/project-manager/grass/grassSVN/grass/trunk/imagery/i.landsat.toar/landsat_set.c clones of sensor_MSS are:
          /data/project-manager/grass/grassSVN/grass-addons/grass7/imagery/i.landsat.toar/landsat_set.c  sensor_MSS
          /data/project-manager/grass/grassSVN/grass-addons/imagery/i.landsat.toar/landsat_set.c  sensor_MSS
In /data/project-manager/grass/grassSVN/grass/trunk/imagery/i.landsat.toar/landsat_set.c clones of sensor_TM are:
          /data/project-manager/grass/grassSVN/grass-addons/grass7/imagery/i.landsat.toar/landsat_set.c  sensor_TM
          /data/project-manager/grass/grassSVN/grass-addons/imagery/i.landsat.toar/landsat_set.c  sensor_TM
In /data/project-manager/grass/grassSVN/grass/trunk/imagery/i.landsat.toar/landsat_set.c clones of set_ETM are:
          /data/project-manager/grass/grassSVN/grass-addons/imagery/i.landsat.toar/landsat_set.c  set_ETM
In /data/project-manager/grass/grassSVN/grass/trunk/imagery/i.landsat.toar/landsat_set.c clones of set_MSS1 are:
          /data/project-manager/grass/grassSVN/grass-addons/grass7/imagery/i.landsat.toar/landsat_set.c  set_MSS1
          /data/project-manager/grass/grassSVN/grass-addons/imagery/i.landsat.toar/landsat_set.c  set_MSS1
In /data/project-manager/grass/grassSVN/grass/trunk/imagery/i.landsat.toar/landsat_set.c clones of set_MSS2 are:
          /data/project-manager/grass/grassSVN/grass-addons/imagery/i.landsat.toar/landsat_set.c  set_MSS2
In /data/project-manager/grass/grassSVN/grass/trunk/imagery/i.landsat.toar/landsat_set.c clones of set_MSS3 are:
          /data/project-manager/grass/grassSVN/grass-addons/imagery/i.landsat.toar/landsat_set.c  set_MSS3
In /data/project-manager/grass/grassSVN/grass/trunk/imagery/i.landsat.toar/landsat_set.c clones of set_MSS4 are:
          /data/project-manager/grass/grassSVN/grass-addons/imagery/i.landsat.toar/landsat_set.c  set_MSS4
In /data/project-manager/grass/grassSVN/grass/trunk/imagery/i.landsat.toar/landsat_set.c clones of set_MSS5 are:
          /data/project-manager/grass/grassSVN/grass-addons/imagery/i.landsat.toar/landsat_set.c  set_MSS5
In /data/project-manager/grass/grassSVN/grass/trunk/imagery/i.landsat.toar/landsat_set.c clones of set_TM4 are:
          /data/project-manager/grass/grassSVN/grass-addons/imagery/i.landsat.toar/landsat_set.c  set_TM4
          File :/imagery/i.landsat.toar/earth_sun.c
          Function
earth_sun(Begins at: 1085, Ends at:1101)
LOC:          |      17 |       |           OK |        17 |
metrics are OK
julian_char(Begins at: 1073, Ends at:1082)
LOC:          |      10 |       |           OK |        10 |
metrics are OK
julian_int(Begins at: 1051, Ends at:1070)
LOC:          |      20 |       |           OK |        20 |
ln_calc_series(Begins at: 1037, Ends at:1048)
LOC:          |      12 |       |           OK |        12 |
Clone analysis:
  julian_char  julian_int  ln_calc_series
In /data/project-manager/grass/grassSVN/grass/trunk/imagery/i.landsat.toar/earth_sun.c clones of earth_sun are:
          /data/project-manager/grass/grassSVN/grass-addons/imagery/i.landsat.toar/earth_sun.c  earth_sun
In /data/project-manager/grass/grassSVN/grass/trunk/imagery/i.landsat.toar/earth_sun.c clones of julian_char are:
          /data/project-manager/grass/grassSVN/grass-addons/imagery/i.landsat.toar/earth_sun.c  julian_char
In /data/project-manager/grass/grassSVN/grass/trunk/imagery/i.landsat.toar/earth_sun.c clones of julian_int are:
          /data/project-manager/grass/grassSVN/grass-addons/imagery/i.landsat.toar/earth_sun.c  julian_int
In /data/project-manager/grass/grassSVN/grass/trunk/imagery/i.landsat.toar/earth_sun.c clones of ln_calc_series are:
          /data/project-manager/grass/grassSVN/grass-addons/imagery/i.landsat.toar/earth_sun.c  ln_calc_series
____________________________________________
Threshold grass key metrics values at Wed Nov 03 06:02:07 EDT 2010 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         9 |        19 |        30 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        18 |        43 |        69 |
LOC:                  |        67 |       151 |       235 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
