[GRASS-QA] GRASS QA: martinl |main.c landsat.c landsat_met.c
landsat_set.c | 5 clones | 1 monsters |4 warnings
soccerlab.info at gmail.com
Wed Nov 3 08:06:20 EDT 2010
Hello martinl,
here's a report on your recent grass-SVN change for the revision : 44032
ANALYSIS
your changes to files/class/methods/functions :
File :/imagery/i.landsat.toar/main.c
Function
main(Begins at: 29, Ends at:632)
| New Metrics |Old Metrics|
Complexity: | 66 | *** | MONSTER | 66 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 219 | *** | MONSTER | 219 |
LOC: | 604 | *** | MONSTER | 604 |
Conclusion: | this function is a MONSTER |
metric are OUT OF RANGE!
Clone analysis:
This file does not contain cloned functions
File :/imagery/i.landsat.toar/landsat.c
Function
lsat_bandctes(Begins at: 51, Ends at:168)
Complexity: | 11 | * | WARNING | 11 |
ParamNBR: | 7 | ** | BABY-MONSTER | 7 |
CalledNBR: | 7 | | OK | 7 |
LOC: | 118 | * | WARNING | 118 |
Conclusion: | this function is a BABY-MONSTER |
Clone analysis:
This file has 1 potentially cloned functions:
In /data/project-manager/grass/grassSVN/grass/trunk/imagery/i.landsat.toar/landsat.c clones of lsat_bandctes are:
/data/project-manager/grass/grassSVN/grass-addons/imagery/i.landsat.toar/landsat.c lsat_bandctes
File :/imagery/i.landsat.toar/landsat_met.c
Function
mtl_TM5(Begins at: 224, Ends at:285)
Complexity: | 7 | | OK | 7 |
CalledNBR: | 29 | * | WARNING | 29 |
LOC: | 62 | | OK | 62 |
Conclusion: | this function is a WARNING |
at least 1 values are close to an outlier please consider revising code!
met_TM5(Begins at: 137, Ends at:207)
Complexity: | 14 | * | WARNING | 14 |
CalledNBR: | 28 | * | WARNING | 28 |
LOC: | 71 | * | WARNING | 71 |
at least 3 values are close to an outlier please consider revising code!
get_value_met7(Begins at: 27, Ends at:41)
Complexity: | 3 | | OK | 3 |
ParamNBR: | 3 | * | WARNING | 3 |
CalledNBR: | 2 | | OK | 2 |
LOC: | 15 | | OK | 15 |
Clone analysis:
This file has 2 potentially cloned functions:
get_value_met7
In /data/project-manager/grass/grassSVN/grass/trunk/imagery/i.landsat.toar/landsat_met.c clones of met_TM5 are:
/data/project-manager/grass/grassSVN/grass-addons/imagery/i.landsat.toar/landsat_met.c met_TM5
In /data/project-manager/grass/grassSVN/grass/trunk/imagery/i.landsat.toar/landsat_met.c clones of get_value_met7 are:
/data/project-manager/grass/grassSVN/grass-addons/imagery/i.landsat.toar/landsat_met.c get_value_met7
File :/imagery/i.landsat.toar/landsat_set.c
Function
sensor_TM(Begins at: 38, Ends at:62)
ParamNBR: | 1 | | OK | 1 |
CalledNBR: | 1 | | OK | 1 |
LOC: | 25 | | OK | 25 |
Conclusion: | this function is a OK |
metrics are OK
Clone analysis:
sensor_TM
In /data/project-manager/grass/grassSVN/grass/trunk/imagery/i.landsat.toar/landsat_set.c clones of sensor_TM are:
/data/project-manager/grass/grassSVN/grass-addons/grass7/imagery/i.landsat.toar/landsat_set.c sensor_TM
/data/project-manager/grass/grassSVN/grass-addons/imagery/i.landsat.toar/landsat_set.c sensor_TM
____________________________________________
Threshold grass key metrics values at Wed Nov 03 08:06:15 EDT 2010 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 9 | 19 | 30 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 18 | 43 | 69 |
LOC: | 67 | 151 | 235 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
