[GRASS-QA] GRASS QA: martinl |main.c tools.c main.c local_proto.h ...| 4 clones | 2 monsters |5 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Wed Nov 3 08:25:24 EDT 2010
Hello martinl,
here's a report on your recent grass-SVN change for the revision : 44039
ANALYSIS
your changes to files/class/methods/functions :
          File :/imagery/i.landsat.toar/main.c
          Function
main(Begins at: 29, Ends at:632)
              |          New Metrics           |Old Metrics|
Complexity:   |      66 |   *** |      MONSTER |        66 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |     219 |   *** |      MONSTER |       219 |
LOC:          |     604 |   *** |      MONSTER |       604 |
Conclusion:   | this function is a       MONSTER           |
 metric are OUT OF RANGE!
Clone analysis:
This file does not contain cloned functions
          File :/imagery/i.landsat.acca/tools.c
          Function
filter_holes(Begins at: 109, Ends at:303)
Complexity:   |      26 |    ** | BABY-MONSTER |        26 |
ParamNBR:     |       1 |       |           OK |         1 |
CalledNBR:    |      79 |   *** |      MONSTER |        79 |
LOC:          |     195 |    ** | BABY-MONSTER |       195 |
hist_put(Begins at: 27, Ends at:40)
Complexity:   |       3 |       |           OK |         3 |
CalledNBR:    |       0 |       |           OK |         0 |
LOC:          |      14 |       |           OK |        14 |
Conclusion:   | this function is a            OK           |
metrics are OK
moment(Begins at: 43, Ends at:65)
ParamNBR:     |       3 |     * |      WARNING |         3 |
CalledNBR:    |       2 |       |           OK |         2 |
LOC:          |      23 |       |           OK |        23 |
Conclusion:   | this function is a       WARNING           |
 at least 1 values are close to an outlier please consider revising code!
pval(Begins at: 99, Ends at:107)
Complexity:   |       2 |       |           OK |         2 |
CalledNBR:    |       1 |       |           OK |         1 |
LOC:          |       9 |       |           OK |         9 |
metrics are OK
quantile(Begins at: 68, Ends at:91)
Complexity:   |       4 |       |           OK |         4 |
LOC:          |      24 |       |           OK |        24 |
metrics are OK
Clone analysis:
This file has 3 potentially cloned functions:
  moment  quantile
In /data/project-manager/grass/grassSVN/grass/trunk/imagery/i.landsat.acca/tools.c clones of hist_put are:
          /data/project-manager/grass/grassSVN/grass-addons/imagery/i.landsat.acca/tools.c  hist_put
In /data/project-manager/grass/grassSVN/grass/trunk/imagery/i.landsat.acca/tools.c clones of moment are:
          /data/project-manager/grass/grassSVN/grass-addons/imagery/i.landsat.acca/tools.c  moment
In /data/project-manager/grass/grassSVN/grass/trunk/imagery/i.landsat.acca/tools.c clones of quantile are:
          /data/project-manager/grass/grassSVN/grass-addons/imagery/i.landsat.acca/tools.c  quantile
          File :/imagery/i.landsat.acca/main.c
          Function
check_raster(Begins at: 50, Ends at:73)
CalledNBR:    |       6 |       |           OK |         6 |
metrics are OK
main(Begins at: 80, Ends at:222)
Complexity:   |       7 |       |           OK |         7 |
CalledNBR:    |      56 |    ** | BABY-MONSTER |        56 |
LOC:          |     143 |     * |      WARNING |       143 |
Conclusion:   | this function is a  BABY-MONSTER           |
Clone analysis:
          File :/imagery/i.landsat.acca/local_proto.h
The system don't find class, method and function
 in this file during analysis!
          File :/imagery/i.landsat.acca/algorithm.c
          Function
acca_algorithm(Begins at: 76, Ends at:211)
Complexity:   |      12 |     * |      WARNING |        12 |
ParamNBR:     |       5 |     * |      WARNING |         5 |
CalledNBR:    |      50 |    ** | BABY-MONSTER |        50 |
LOC:          |     136 |     * |      WARNING |       136 |
acca_first(Begins at: 214, Ends at:358)
Complexity:   |      21 |    ** | BABY-MONSTER |        21 |
ParamNBR:     |       7 |    ** | BABY-MONSTER |         7 |
CalledNBR:    |      19 |     * |      WARNING |        19 |
LOC:          |     145 |     * |      WARNING |       145 |
acca_second(Begins at: 361, Ends at:449)
Complexity:   |      10 |     * |      WARNING |        10 |
CalledNBR:    |      38 |     * |      WARNING |        38 |
LOC:          |      89 |     * |      WARNING |        89 |
 at least 4 values are close to an outlier please consider revising code!
shadow_algorithm(Begins at: 457, Ends at:472)
LOC:          |      16 |       |           OK |        16 |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
In /data/project-manager/grass/grassSVN/grass/trunk/imagery/i.landsat.acca/algorithm.c clones of shadow_algorithm are:
          /data/project-manager/grass/grassSVN/grass-addons/imagery/i.landsat.acca/algorithm.c  shadow_algorithm
____________________________________________
Threshold grass key metrics values at Wed Nov 03 08:25:19 EDT 2010 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         9 |        19 |        30 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        18 |        43 |        69 |
LOC:                  |        67 |       151 |       235 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
