[GRASS-QA] GRASS QA: mmetz |interp.c | 1 clones | 1 monsters |2 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Wed Nov 3 10:11:20 EDT 2010
Hello mmetz,
here's a report on your recent grass-SVN change for the revision : 44071
ANALYSIS
your changes to files/class/methods/functions :
          File :/lib/raster/interp.c
          Function
Rast_interp_cubic_bspline(Begins at: 89, Ends at:95)
              |          New Metrics           |Old Metrics|
Complexity:   |       1 |       |           OK |         1 |
ParamNBR:     |       5 |     * |      WARNING |         5 |
CalledNBR:    |       0 |       |           OK |         0 |
LOC:          |       7 |       |           OK |         7 |
Conclusion:   | this function is a       WARNING           |
 at least 1 values are close to an outlier please consider revising code!
Rast_interp_bicubic_bspline(Begins at: 97, Ends at:109)
ParamNBR:     |      18 |   *** |      MONSTER |        18 |
CalledNBR:    |       5 |       |           OK |         5 |
LOC:          |      13 |       |           OK |        13 |
Conclusion:   | this function is a       MONSTER           |
 metric are OUT OF RANGE!
Rast_interp_lanczos(Begins at: 55, Ends at:87)
Complexity:   |       4 |       |           OK |         4 |
ParamNBR:     |       3 |     * |      WARNING |         3 |
CalledNBR:    |       2 |       |           OK |         2 |
LOC:          |      33 |       |           OK |        33 |
Clone analysis:
This file has 1 potentially cloned functions:
In /data/project-manager/grass/grassSVN/grass/trunk/lib/raster/interp.c clones of Rast_interp_bicubic_bspline are:
          /data/project-manager/grass/grassSVN/grass/trunk/lib/raster/interp.c  Rast_interp_bicubic
____________________________________________
Threshold grass key metrics values at Wed Nov 03 10:11:13 EDT 2010 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         9 |        19 |        30 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        18 |        43 |        69 |
LOC:                  |        67 |       151 |       235 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
