[GRASS-QA] GRASS QA: martinl |rasterdefs.h main.c color_print.c | no clones | 1 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Wed Nov 3 12:48:57 EDT 2010
Hello martinl,
here's a report on your recent grass-SVN change for the revision : 44133
ANALYSIS
your changes to files/class/methods/functions :
          File :/include/rasterdefs.h
The system don't find class, method and function
 in this file during analysis!
          File :/raster/r.colors/main.c
          Function
main(Begins at: 139, Ends at:395)
              |          New Metrics           |Old Metrics|
Complexity:   |      38 |   *** |      MONSTER |        38 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |     113 |   *** |      MONSTER |       113 |
LOC:          |     257 |   *** |      MONSTER |       257 |
Conclusion:   | this function is a       MONSTER           |
 metric are OUT OF RANGE!
rules_list(Begins at: 55, Ends at:79)
Complexity:   |       4 |       |           OK |         4 |
ParamNBR:     |       1 |       |           OK |         1 |
CalledNBR:    |       3 |       |           OK |         3 |
LOC:          |      25 |       |           OK |        25 |
Conclusion:   | this function is a            OK           |
metrics are OK
scan_rules(Begins at: 38, Ends at:53)
Complexity:   |       1 |       |           OK |         1 |
CalledNBR:    |      10 |       |           OK |        10 |
LOC:          |      16 |       |           OK |        16 |
metrics are OK
cmp(Begins at: 30, Ends at:36)
CalledNBR:    |       1 |       |           OK |         1 |
LOC:          |       7 |       |           OK |         7 |
metrics are OK
Clone analysis:
This file does not contain cloned functions
          File :/lib/raster/color_print.c
____________________________________________
Threshold grass key metrics values at Wed Nov 03 12:48:48 EDT 2010 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         9 |        19 |        30 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        18 |        43 |        69 |
LOC:                  |        67 |       151 |       235 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
