[GRASS-QA] GRASS QA: martinl |proto.h args.c main.c | no clones | 1
monsters |1 warnings
soccerlab.info at gmail.com
Mon Nov 29 13:40:34 EST 2010
Hello martinl,
here's a report on your recent grass-SVN change for the revision : 44216
ANALYSIS
your changes to files/class/methods/functions :
File :/vector/v.select/proto.h
Class
GFlag(Begins at: 19, Ends at:21)
| DIT | NOC | WMC | RFC | CBO | LCOM |
|NEW Metrics | 1 | 0 | 0 | 0 | 0 | 0 |
|OLD Metrics | 1 | 0 | 0 | 0 | 0 | 0 |
Class
GParm(Begins at: 15, Ends at:18)
Clone analysis:
This file does not contain cloned functions
File :/vector/v.select/args.c
Function
parse_options(Begins at: 7, Ends at:89)
| New Metrics |Old Metrics|
Complexity: | 1 | | OK | 1 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 31 | * | WARNING | 31 |
LOC: | 83 | * | WARNING | 83 |
Conclusion: | this function is a WARNING |
at least 2 values are close to an outlier please consider revising code!
Clone analysis:
File :/vector/v.select/main.c
Function
main(Begins at: 28, Ends at:539)
Complexity: | 77 | *** | MONSTER | 77 |
CalledNBR: | 140 | *** | MONSTER | 140 |
LOC: | 512 | *** | MONSTER | 512 |
Conclusion: | this function is a MONSTER |
metric are OUT OF RANGE!
Clone analysis:
____________________________________________
Threshold grass key metrics values at Mon Nov 29 13:40:23 EST 2010 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 9 | 19 | 30 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 18 | 43 | 69 |
LOC: | 67 | 151 | 235 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
