[GRASS-QA] GRASS QA: huhabla |parser_wps.c | 1 clones | 1 monsters |1 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Mon Nov 29 19:48:56 EST 2010
Hello huhabla,
here's a report on your recent grass-SVN change for the revision : 44362
ANALYSIS
your changes to files/class/methods/functions :
          File :/lib/gis/parser_wps.c
          Function
wps_print_process_description_begin(Begins at: 448, Ends at:490)
              |          New Metrics           |Old Metrics|
Complexity:   |       5 |       |           OK |         5 |
ParamNBR:     |       7 |    ** | BABY-MONSTER |         7 |
CalledNBR:    |      17 |       |           OK |        17 |
LOC:          |      43 |       |           OK |        43 |
Conclusion:   | this function is a  BABY-MONSTER           |
 metric are OUT OF RANGE!
wps_print_literal_input_output(Begins at: 657, Ends at:739)
Complexity:   |      14 |     * |      WARNING |        14 |
ParamNBR:     |      12 |   *** |      MONSTER |        12 |
CalledNBR:    |      36 |     * |      WARNING |        36 |
LOC:          |      83 |     * |      WARNING |        83 |
Conclusion:   | this function is a       MONSTER           |
Clone analysis:
This file has 1 potentially cloned functions:
In /data/project-manager/grass/grassSVN/grass/trunk/lib/gis/parser_wps.c clones of wps_print_literal_input_output are:
          /var/project-manager/grass/grassSVN/grass/trunk/lib/gis/parser_wps.c  wps_print_literal_input_output
____________________________________________
Threshold grass key metrics values at Mon Nov 29 19:48:40 EST 2010 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         9 |        19 |        30 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        18 |        43 |        69 |
LOC:                  |        68 |       153 |       239 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
