[GRASS-QA] GRASS QA: glynn |main.c parser.c parser_script.c gis.h ...| no clones | 3 monsters |3 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Mon Nov 29 22:15:45 EST 2010
Hello glynn,
here's a report on your recent grass-SVN change for the revision : 44421
ANALYSIS
your changes to files/class/methods/functions :
          File :/general/g.parser/main.c
          Class
context(Begins at: 36, Ends at:46)
             |    DIT |    NOC |    WMC |    RFC |    CBO |   LCOM |
|NEW Metrics |      1 |      0 |      0 |      0 |      0 |      0 |
|OLD Metrics |        |        |        |        |        |        |
          Function
parse_type(Begins at: 188, Ends at:202)
              |          New Metrics           |Old Metrics|
Complexity:   |       4 |       |           OK |         4 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |       4 |       |           OK |         4 |
LOC:          |      15 |       |           OK |        15 |
Conclusion:   | this function is a            OK           |
metrics are OK
parse_flag(Begins at: 146, Ends at:186)
Complexity:   |       8 |       |           OK |         8 |
ParamNBR:     |       3 |     * |      WARNING |         3 |
CalledNBR:    |      16 |       |           OK |        16 |
LOC:          |      41 |       |           OK |        41 |
Conclusion:   | this function is a       WARNING           |
 at least 1 values are close to an outlier please consider revising code!
translate(Begins at: 52, Ends at:74)
ParamNBR:     |       1 |       |           OK |         1 |
CalledNBR:    |       7 |       |           OK |         7 |
LOC:          |      23 |       |           OK |        23 |
metrics are OK
parse_toplevel(Begins at: 90, Ends at:115)
Complexity:   |       6 |       |           OK |         6 |
LOC:          |      26 |       |           OK |        26 |
metrics are OK
parse_boolean(Begins at: 76, Ends at:88)
Complexity:   |       3 |       |           OK |         3 |
CalledNBR:    |       3 |       |           OK |         3 |
LOC:          |      13 |       |           OK |        13 |
metrics are OK
parse_option(Begins at: 204, Ends at:280)
Complexity:   |      15 |     * |      WARNING |        15 |
CalledNBR:    |      33 |     * |      WARNING |        33 |
LOC:          |      77 |     * |      WARNING |        77 |
 at least 4 values are close to an outlier please consider revising code!
Clone analysis:
This file does not contain cloned functions
          File :/lib/gis/parser.c
          Function
G_parser(Begins at: 310, Ends at:571)
Complexity:   |      43 |   *** |      MONSTER |        43 |
CalledNBR:    |      86 |   *** |      MONSTER |        86 |
LOC:          |     262 |   *** |      MONSTER |       262 |
Conclusion:   | this function is a       MONSTER           |
 metric are OUT OF RANGE!
set_flag(Begins at: 786, Ends at:812)
Complexity:   |       5 |       |           OK |         5 |
LOC:          |      27 |       |           OK |        27 |
metrics are OK
Clone analysis:
          File :/lib/gis/parser_script.c
          Function
G__script(Begins at: 21, Ends at:129)
Complexity:   |      26 |    ** | BABY-MONSTER |        26 |
CalledNBR:    |      48 |    ** | BABY-MONSTER |        48 |
LOC:          |     109 |     * |      WARNING |       109 |
Conclusion:   | this function is a  BABY-MONSTER           |
Clone analysis:
          File :/include/gis.h
          Class
Cell_head(Begins at: 255, Ends at:277)
          Class
Counter(Begins at: 375, Ends at:377)
          Class
Flag(Begins at: 348, Ends at:357)
          Class
GModule(Begins at: 359, Ends at:367)
          Class
G_3dview(Begins at: 282, Ends at:307)
          Class
Key_Value(Begins at: 309, Ends at:315)
          Class
Option(Begins at: 317, Ends at:346)
|NEW Metrics |      1 |      0 |      0 |      1 |      0 |      0 |
          Class
Popen(Begins at: 379, Ends at:382)
          Class
TimeStamp(Begins at: 369, Ends at:373)
Clone analysis:
          File :/general/g.mapset/main.c
          Function
main(Begins at: 28, Ends at:216)
Complexity:   |      19 |    ** | BABY-MONSTER |        19 |
LOC:          |     189 |    ** | BABY-MONSTER |       189 |
Clone analysis:
          File :/lib/gis/parser_local_proto.h
          Class
Item(Begins at: 7, Ends at:12)
          Class
state(Begins at: 14, Ends at:39)
Clone analysis:
          File :/lib/gis/parser_interface.c
          Function
G__usage_xml(Begins at: 103, Ends at:349)
Complexity:   |      33 |   *** |      MONSTER |        33 |
CalledNBR:    |      97 |   *** |      MONSTER |        97 |
LOC:          |     247 |   *** |      MONSTER |       247 |
Clone analysis:
____________________________________________
Threshold grass key metrics values at Mon Nov 29 22:15:27 EST 2010 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         9 |        19 |        30 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        18 |        43 |        69 |
LOC:                  |        68 |       153 |       239 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
