[GRASS-QA] GRASS QA: mmetz |list.c create.c attrb.c args.c | no
clones | 1 monsters |3 warnings
soccerlab.info at gmail.com
Tue Nov 30 00:23:22 EST 2010
Hello mmetz,
here's a report on your recent grass-SVN change for the revision : 44465
ANALYSIS
your changes to files/class/methods/functions :
File :/vector/v.out.ogr/list.c
Function
OGR_list_write_drivers(Begins at: 4, Ends at:35)
| New Metrics |Old Metrics|
Complexity: | 4 | | OK | 4 |
ParamNBR: | 1 | | OK | 1 |
CalledNBR: | 18 | * | WARNING | 18 |
LOC: | 32 | | OK | 32 |
Conclusion: | this function is a WARNING |
at least 1 values are close to an outlier please consider revising code!
Clone analysis:
This file does not contain cloned functions
File :/vector/v.out.ogr/create.c
Function
create_ogr_layer(Begins at: 5, Ends at:38)
ParamNBR: | 6 | ** | BABY-MONSTER | 6 |
CalledNBR: | 12 | | OK | 12 |
LOC: | 34 | | OK | 34 |
Conclusion: | this function is a BABY-MONSTER |
metric are OUT OF RANGE!
Clone analysis:
File :/vector/v.out.ogr/attrb.c
Function
mk_att(Begins at: 5, Ends at:128)
Complexity: | 15 | * | WARNING | 15 |
ParamNBR: | 9 | *** | MONSTER | 9 |
CalledNBR: | 45 | ** | BABY-MONSTER | 45 |
LOC: | 124 | * | WARNING | 124 |
Conclusion: | this function is a MONSTER |
Clone analysis:
File :/vector/v.out.ogr/args.c
Function
parse_args(Begins at: 5, Ends at:103)
Complexity: | 2 | | OK | 2 |
ParamNBR: | 4 | * | WARNING | 4 |
CalledNBR: | 38 | * | WARNING | 38 |
LOC: | 99 | * | WARNING | 99 |
at least 3 values are close to an outlier please consider revising code!
Clone analysis:
____________________________________________
Threshold grass key metrics values at Tue Nov 30 00:23:02 EST 2010 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 10 | 22 | 34 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 18 | 43 | 69 |
LOC: | 68 | 153 | 239 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
