[GRASS-QA] GRASS QA: ejtizado |correction.c main.c local_proto.h |
no clones | 1 monsters |1 warnings
soccerlab.info at gmail.com
Fri Sep 3 12:01:18 EDT 2010
Hello ejtizado,
here's a report on your recent grass-SVN change for the revision : 43396
ANALYSIS
your changes to files/class/methods/functions :
File :/imagery/i.topo.corr/correction.c
Function
eval_tcor(Begins at: 10, Ends at:145)
| New Metrics |Old Metrics|
Complexity: | 25 | ** | BABY-MONSTER | 25 |
ParamNBR: | 5 | * | WARNING | 5 |
CalledNBR: | 20 | * | WARNING | 20 |
LOC: | 136 | * | WARNING | 136 |
Conclusion: | this function is a BABY-MONSTER |
metric are OUT OF RANGE!
Clone analysis:
This file does not contain cloned functions
File :/imagery/i.topo.corr/main.c
Function
full_open_old(Begins at: 25, Ends at:43)
Complexity: | 3 | | OK | 3 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 7 | | OK | 7 |
LOC: | 19 | | OK | 19 |
Conclusion: | this function is a OK |
metrics are OK
main(Begins at: 63, Ends at:259)
Complexity: | 15 | * | WARNING | 15 |
CalledNBR: | 88 | *** | MONSTER | 88 |
LOC: | 197 | ** | BABY-MONSTER | 197 |
Conclusion: | this function is a MONSTER |
Clone analysis:
File :/imagery/i.topo.corr/local_proto.h
The system don't find class, method and function
in this file during analysis!
____________________________________________
Threshold grass key metrics values at Fri Sep 03 12:01:14 EDT 2010 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 9 | 19 | 30 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 18 | 43 | 69 |
LOC: | 67 | 151 | 235 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
