[GRASS-QA] GRASS QA: ejtizado |main.c landsat_set.c | no clones | 0
	monsters |0 warnings
    soccerlab.info at gmail.com
    Mon Sep  6 12:40:18 EDT 2010
Hello ejtizado,
here's a report on your recent grass-SVN change for the revision : 43419
ANALYSIS
your changes to files/class/methods/functions :
          File :/imagery/i.landsat.toar/main.c
The system don't find class, method and function
 in this file during analysis!
          File :/imagery/i.landsat.toar/landsat_set.c
          Function
sensor_MSS(Begins at: 12, Ends at:36)
              |          New Metrics           |Old Metrics|
Complexity:   |       2 |       |           OK |         2 |
ParamNBR:     |       1 |       |           OK |         1 |
CalledNBR:    |       1 |       |           OK |         1 |
LOC:          |      25 |       |           OK |        25 |
Conclusion:   | this function is a            OK           |
metrics are OK
Clone analysis:
This file does not contain cloned functions
____________________________________________
Threshold grass key metrics values at Mon Sep 06 12:40:12 EDT 2010 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         9 |        19 |        30 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        18 |        43 |        69 |
LOC:                  |        66 |       149 |       233 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
