[GRASS-QA] GRASS QA: huhabla |column.c column.c test_main.c
	dbmscap.c ...| 8 clones | 0 monsters |12 warnings
    soccerlab.info at gmail.com
    Mon Sep 13 14:14:03 EDT 2010
Hello huhabla,
here's a report on your recent grass-SVN change for the revision : 43453
ANALYSIS
your changes to files/class/methods/functions :
          File :/lib/db/dbmi_base/column.c
          Function
db_free_column(Begins at: 451, Ends at:458)
              |          New Metrics           |Old Metrics|
Complexity:   |       1 |       |           OK |         1 |
ParamNBR:     |       1 |       |           OK |         1 |
CalledNBR:    |       4 |       |           OK |         4 |
LOC:          |       8 |       |           OK |         8 |
Conclusion:   | this function is a            OK           |
metrics are OK
db_copy_column(Begins at: 468, Ends at:493)
Complexity:   |       2 |       |           OK |         2 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |       7 |       |           OK |         7 |
LOC:          |      26 |       |           OK |        26 |
metrics are OK
Clone analysis:
This file does not contain cloned functions
          File :/lib/db/dbmi_client/column.c
          Function
db_get_column(Begins at: 98, Ends at:127)
Complexity:   |       4 |       |           OK |         4 |
ParamNBR:     |       4 |     * |      WARNING |         4 |
CalledNBR:    |      11 |       |           OK |        11 |
LOC:          |      30 |       |           OK |        30 |
Conclusion:   | this function is a       WARNING           |
 at least 1 values are close to an outlier please consider revising code!
Clone analysis:
          File :/lib/db/dbmi_base/test/test_main.c
          Function
main(Begins at: 74, Ends at:133)
Complexity:   |      14 |     * |      WARNING |        14 |
CalledNBR:    |      14 |       |           OK |        14 |
LOC:          |      60 |       |           OK |        60 |
set_params(Begins at: 41, Ends at:68)
CalledNBR:    |      10 |       |           OK |        10 |
LOC:          |      28 |       |           OK |        28 |
metrics are OK
Clone analysis:
          File :/lib/db/dbmi_base/dbmscap.c
          Function
add_entry(Begins at: 206, Ends at:234)
CalledNBR:    |       5 |       |           OK |         5 |
LOC:          |      29 |       |           OK |        29 |
db_copy_dbmscap_entry(Begins at: 81, Ends at:86)
CalledNBR:    |       3 |       |           OK |         3 |
LOC:          |       6 |       |           OK |         6 |
metrics are OK
db_dbmscap_filename(Begins at: 59, Ends at:62)
CalledNBR:    |       1 |       |           OK |         1 |
LOC:          |       4 |       |           OK |         4 |
metrics are OK
db_free_dbmscap(Begins at: 241, Ends at:249)
LOC:          |       9 |       |           OK |         9 |
metrics are OK
db_has_dbms(Begins at: 70, Ends at:73)
metrics are OK
db_read_dbmscap(Begins at: 100, Ends at:204)
CalledNBR:    |      31 |     * |      WARNING |        31 |
LOC:          |     105 |     * |      WARNING |       105 |
 at least 2 values are close to an outlier please consider revising code!
dbmscap_filename(Begins at: 35, Ends at:52)
Complexity:   |       5 |       |           OK |         5 |
LOC:          |      18 |       |           OK |        18 |
metrics are OK
Clone analysis:
          File :/lib/db/dbmi_client/printtab.c
          Function
db_print_column_definition(Begins at: 51, Ends at:72)
CalledNBR:    |      24 |     * |      WARNING |        24 |
LOC:          |      22 |       |           OK |        22 |
db_print_table_definition(Begins at: 26, Ends at:43)
CalledNBR:    |      13 |       |           OK |        13 |
metrics are OK
print_priv(Begins at: 74, Ends at:89)
ParamNBR:     |       3 |     * |      WARNING |         3 |
LOC:          |      16 |       |           OK |        16 |
Clone analysis:
          File :/lib/db/dbmi_base/test/test_columns.c
          Function
test_copy_column(Begins at: 52, Ends at:153)
Complexity:   |      15 |     * |      WARNING |        15 |
CalledNBR:    |      46 |    ** | BABY-MONSTER |        46 |
LOC:          |     102 |     * |      WARNING |       102 |
Conclusion:   | this function is a  BABY-MONSTER           |
 metric are OUT OF RANGE!
unit_test_column(Begins at: 33, Ends at:47)
LOC:          |      15 |       |           OK |        15 |
metrics are OK
Clone analysis:
This file has 4 potentially cloned functions:
  unit_test_ccmath_wrapper  unit_test_matrix_conversion  unit_test_solvers
In /data/project-manager/grass/grassSVN/grass/trunk/lib/db/dbmi_base/test/test_columns.c clones of unit_test_column are:
          /data/project-manager/grass/grassSVN/grass/trunk/lib/db/dbmi_base/test/test_table.c  unit_test_table
          /data/project-manager/grass/grassSVN/grass/trunk/lib/gmath/test/test_ccmath_wrapper.c  unit_test_ccmath_wrapper
          /data/project-manager/grass/grassSVN/grass/trunk/lib/gmath/test/test_matrix_conversion.c  unit_test_matrix_conversion
          /data/project-manager/grass/grassSVN/grass/trunk/lib/gmath/test/test_solvers.c  unit_test_solvers
          File :/lib/db/dbmi_base/test/test_dbmi_base_lib.h
The system don't find class, method and function
 in this file during analysis!
          File :/lib/db/dbmi_base/dirent.c
          Function
cmp_dirent(Begins at: 128, Ends at:135)
metrics are OK
db_alloc_dirent_array(Begins at: 148, Ends at:161)
Complexity:   |       3 |       |           OK |         3 |
LOC:          |      14 |       |           OK |        14 |
metrics are OK
db_dirent(Begins at: 35, Ends at:93)
Complexity:   |       9 |     * |      WARNING |         9 |
CalledNBR:    |      19 |     * |      WARNING |        19 |
LOC:          |      59 |       |           OK |        59 |
db_free_dirent_array(Begins at: 101, Ends at:110)
CalledNBR:    |       2 |       |           OK |         2 |
LOC:          |      10 |       |           OK |        10 |
metrics are OK
get_perm(Begins at: 112, Ends at:126)
metrics are OK
sort_dirent(Begins at: 137, Ends at:140)
metrics are OK
Clone analysis:
          File :/include/proto_dbmi.h
          File :/lib/db/dbmi_base/table.c
          Function
db_alloc_table(Begins at: 10, Ends at:31)
metrics are OK
db_append_table_column(Begins at: 311, Ends at:319)
metrics are OK
db_clone_table(Begins at: 330, Ends at:351)
metrics are OK
db_free_table(Begins at: 48, Ends at:58)
LOC:          |      11 |       |           OK |        11 |
metrics are OK
db_get_table_column(Begins at: 277, Ends at:282)
CalledNBR:    |       0 |       |           OK |         0 |
metrics are OK
db_get_table_delete_priv(Begins at: 262, Ends at:265)
metrics are OK
db_get_table_description(Begins at: 97, Ends at:100)
metrics are OK
db_get_table_insert_priv(Begins at: 233, Ends at:236)
metrics are OK
db_get_table_name(Begins at: 76, Ends at:79)
metrics are OK
db_get_table_number_of_columns(Begins at: 107, Ends at:110)
metrics are OK
db_get_table_select_priv(Begins at: 175, Ends at:178)
metrics are OK
db_get_table_update_priv(Begins at: 204, Ends at:207)
metrics are OK
db_init_table(Begins at: 37, Ends at:42)
metrics are OK
db_set_table_column(Begins at: 294, Ends at:300)
LOC:          |       7 |       |           OK |         7 |
db_set_table_delete_priv_granted(Begins at: 242, Ends at:245)
metrics are OK
db_set_table_delete_priv_not_granted(Begins at: 251, Ends at:254)
metrics are OK
db_set_table_description(Begins at: 87, Ends at:90)
metrics are OK
db_set_table_insert_priv_granted(Begins at: 213, Ends at:216)
metrics are OK
db_set_table_insert_priv_not_granted(Begins at: 222, Ends at:225)
metrics are OK
db_set_table_name(Begins at: 66, Ends at:69)
metrics are OK
db_set_table_select_priv_granted(Begins at: 155, Ends at:158)
metrics are OK
db_set_table_select_priv_not_granted(Begins at: 164, Ends at:167)
metrics are OK
db_set_table_update_priv_granted(Begins at: 184, Ends at:187)
metrics are OK
db_set_table_update_priv_not_granted(Begins at: 193, Ends at:196)
metrics are OK
db_table_to_sql(Begins at: 360, Ends at:431)
Complexity:   |      17 |     * |      WARNING |        17 |
CalledNBR:    |      28 |     * |      WARNING |        28 |
LOC:          |      72 |     * |      WARNING |        72 |
 at least 3 values are close to an outlier please consider revising code!
get_all_column_privs(Begins at: 136, Ends at:149)
metrics are OK
set_all_column_privs(Begins at: 118, Ends at:128)
metrics are OK
Clone analysis:
          File :/lib/db/dbmi_base/test/test_table.c
          Function
create_column(Begins at: 128, Ends at:151)
CalledNBR:    |      17 |       |           OK |        17 |
LOC:          |      24 |       |           OK |        24 |
test_table(Begins at: 53, Ends at:123)
Complexity:   |      10 |     * |      WARNING |        10 |
CalledNBR:    |      33 |     * |      WARNING |        33 |
LOC:          |      71 |     * |      WARNING |        71 |
unit_test_table(Begins at: 34, Ends at:48)
metrics are OK
Clone analysis:
In /data/project-manager/grass/grassSVN/grass/trunk/lib/db/dbmi_base/test/test_table.c clones of unit_test_table are:
          /data/project-manager/grass/grassSVN/grass/trunk/lib/db/dbmi_base/test/test_columns.c  unit_test_column
____________________________________________
Threshold grass key metrics values at Mon Sep 13 14:13:55 EDT 2010 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         9 |        19 |        30 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        18 |        43 |        69 |
LOC:                  |        66 |       148 |       231 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
