[GRASS-QA] GRASS QA: huhabla |proto_dbmi.h table.c test_table.c |
no clones | 0 monsters |1 warnings
soccerlab.info at gmail.com
Thu Sep 16 09:03:25 EDT 2010
Hello huhabla,
here's a report on your recent grass-SVN change for the revision : 43479
ANALYSIS
your changes to files/class/methods/functions :
File :/include/proto_dbmi.h
The system don't find class, method and function
in this file during analysis!
File :/lib/db/dbmi_base/table.c
Function
db_get_table_column_by_name(Begins at: 294, Ends at:312)
| New Metrics |Old Metrics|
Complexity: | 4 | | OK | 4 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 3 | | OK | 3 |
LOC: | 19 | | OK | 19 |
Conclusion: | this function is a OK |
metrics are OK
db_get_table_column(Begins at: 278, Ends at:283)
Complexity: | 2 | | OK | 2 |
CalledNBR: | 0 | | OK | 0 |
LOC: | 6 | | OK | 6 |
metrics are OK
Clone analysis:
This file does not contain cloned functions
File :/lib/db/dbmi_base/test/test_table.c
Function
test_table(Begins at: 53, Ends at:150)
Complexity: | 13 | * | WARNING | 13 |
ParamNBR: | 1 | | OK | 1 |
CalledNBR: | 50 | ** | BABY-MONSTER | 50 |
LOC: | 98 | * | WARNING | 98 |
Conclusion: | this function is a BABY-MONSTER |
metric are OUT OF RANGE!
Clone analysis:
____________________________________________
Threshold grass key metrics values at Thu Sep 16 09:03:20 EDT 2010 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 9 | 19 | 30 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 17 | 41 | 65 |
LOC: | 66 | 150 | 234 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
