[GRASS-QA] GRASS QA: hamish |points.c draw.c main.c local_proto.h | no clones | 3 monsters |1 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Sun Apr 3 01:07:01 EDT 2011
Hello hamish,
here's a report on your recent grass-SVN change for the revision : 45827
ANALYSIS
your changes to files/class/methods/functions :
          File :/display/d.barb/points.c
          Function
fill_arrays(Begins at: 141, Ends at:273)
              |          New Metrics           |Old Metrics|
Complexity:   |      21 |    ** | BABY-MONSTER |        21 |
ParamNBR:     |       9 |   *** |      MONSTER |         9 |
CalledNBR:    |      39 |    ** | BABY-MONSTER |        39 |
LOC:          |     133 |     * |      WARNING |       133 |
Conclusion:   | this function is a       MONSTER           |
 metric are OUT OF RANGE!
do_barb_points(Begins at: 10, Ends at:92)
Complexity:   |      10 |     * |      WARNING |        10 |
CalledNBR:    |      28 |     * |      WARNING |        28 |
LOC:          |      83 |     * |      WARNING |        83 |
Clone analysis:
This file does not contain cloned functions
          File :/display/d.barb/draw.c
          Function
draw_barb(Begins at: 11, Ends at:45)
Complexity:   |       3 |       |           OK |         3 |
ParamNBR:     |       7 |    ** | BABY-MONSTER |         7 |
CalledNBR:    |       9 |       |           OK |         9 |
LOC:          |      35 |       |           OK |        35 |
Conclusion:   | this function is a  BABY-MONSTER           |
Clone analysis:
          File :/display/d.barb/main.c
          Function
main(Begins at: 26, Ends at:261)
Complexity:   |      19 |     * |      WARNING |        19 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |      89 |   *** |      MONSTER |        89 |
LOC:          |     236 |   *** |      MONSTER |       236 |
Clone analysis:
          File :/display/d.barb/local_proto.h
The system don't find class, method and function
 in this file during analysis!
____________________________________________
Threshold grass key metrics values at Sun Apr 03 01:06:48 EDT 2011 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         9 |        21 |        33 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        16 |        38 |        61 |
LOC:                  |        64 |       145 |       226 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
