[GRASS-QA] GRASS QA: martinl |distance.c | no clones | 0 monsters |3 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Sun Apr 10 17:06:19 EDT 2011
Hello martinl,
here's a report on your recent grass-SVN change for the revision : 45893
ANALYSIS
your changes to files/class/methods/functions :
          File :/lib/gis/distance.c
          Function
G_begin_distance_calculations(Begins at: 42, Ends at:60)
              |          New Metrics           |Old Metrics|
Complexity:   |       5 |       |           OK |         5 |
ParamNBR:     |       1 |       |           OK |         1 |
CalledNBR:    |       4 |       |           OK |         4 |
LOC:          |      19 |       |           OK |        19 |
Conclusion:   | this function is a            OK           |
metrics are OK
G_distance_between_line_segments(Begins at: 91, Ends at:109)
Complexity:   |       2 |       |           OK |         2 |
ParamNBR:     |       8 |    ** | BABY-MONSTER |         8 |
CalledNBR:    |       6 |       |           OK |         6 |
Conclusion:   | this function is a  BABY-MONSTER           |
 metric are OUT OF RANGE!
G_distance(Begins at: 75, Ends at:81)
ParamNBR:     |       4 |     * |      WARNING |         4 |
CalledNBR:    |       2 |       |           OK |         2 |
LOC:          |       7 |       |           OK |         7 |
Conclusion:   | this function is a       WARNING           |
 at least 1 values are close to an outlier please consider revising code!
G_distance_point_to_line_segment(Begins at: 120, Ends at:168)
Complexity:   |       8 |       |           OK |         8 |
ParamNBR:     |       6 |    ** | BABY-MONSTER |         6 |
CalledNBR:    |      10 |       |           OK |        10 |
LOC:          |      49 |       |           OK |        49 |
Clone analysis:
This file does not contain cloned functions
____________________________________________
Threshold grass key metrics values at Sun Apr 10 17:06:06 EDT 2011 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         9 |        21 |        33 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        16 |        38 |        61 |
LOC:                  |        63 |       142 |       222 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
