[GRASS-QA] GRASS QA: martinl |build_ogr.c open_ogr.c | 1 clones | 0
monsters |3 warnings
soccerlab.info at gmail.com
Tue Apr 12 02:30:52 EDT 2011
Hello martinl,
here's a report on your recent grass-SVN change for the revision : 45910
ANALYSIS
your changes to files/class/methods/functions :
File :/lib/vector/Vlib/build_ogr.c
Function
Vect_build_ogr(Begins at: 338, Ends at:432)
| New Metrics |Old Metrics|
Complexity: | 9 | * | WARNING | 9 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 39 | ** | BABY-MONSTER | 39 |
LOC: | 95 | * | WARNING | 95 |
Conclusion: | this function is a BABY-MONSTER |
metric are OUT OF RANGE!
Clone analysis:
This file has 1 potentially cloned functions:
In /data/project-manager/grass/grassSVN/grass/trunk/lib/vector/Vlib/build_ogr.c clones of Vect_build_ogr are:
/var/project-manager/grass/grassSVN/grass/trunk/lib/vector/Vlib/build_ogr.c Vect_build_ogr
File :/lib/vector/Vlib/open_ogr.c
Function
V2_open_new_ogr(Begins at: 288, Ends at:348)
Complexity: | 12 | * | WARNING | 12 |
CalledNBR: | 16 | * | WARNING | 16 |
LOC: | 61 | | OK | 61 |
Conclusion: | this function is a WARNING |
at least 2 values are close to an outlier please consider revising code!
V1_open_old_ogr(Begins at: 43, Ends at:122)
Complexity: | 17 | * | WARNING | 17 |
CalledNBR: | 22 | * | WARNING | 22 |
LOC: | 80 | * | WARNING | 80 |
at least 3 values are close to an outlier please consider revising code!
Clone analysis:
This file does not contain cloned functions
____________________________________________
Threshold grass key metrics values at Tue Apr 12 02:30:32 EDT 2011 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 9 | 21 | 33 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 16 | 38 | 61 |
LOC: | 63 | 142 | 222 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
